Has it been done?  Google didn't seem to think so.
Seriously considering it however for my 260z.  I've spent a long time tossing up between a VQ35DE Vs RB25DET swap... the VQ25DET seems like it may be the best of both worlds... light like the VQ35, 6-speed box, weight behind the front axle... but with the cool factor and easy mod-ability of a turbo.
Approaching the point in my build that I'll need to make a call and drop some cash soon!
Not really - I'd like something light and higher revving for the zed - nothing against V8's, as I'll likely use one in the project after this, something like an AC cobra replica for example.
But I'm after a different character for the zed.
There are plenty of VQ35 conversion in the states and even a kit to do it, made by Austin Hoke.
http://hokeperformance.squarespace.com/vq240z-build
A built 6 throttle VQ35 with some big cams would be a pretty epic motor in a zed, but then you have a V. 6 cylinders should be inline!
If you are after bang for buck you won't be able to beat an RB25DET though.
  • 3 weeks later...
Can't see any reason to use a VQ25 rather than a 35, there would not be much weight difference. If it was me there would be a LSx going in there, lighter than the L6 and the VQ.
I've got a vq25det in the stagea. Nice engine and moves 2t along well.  Would go well in 1200kg.
As far as I knew though it only came with the 5speed auto.  What car are you getting the 6 speed out of?
Some v35 skylines came with the vq25 and 6 speed combo but only in N/A i believe. I also heard that the z33 350z gearbox fits directly onto the vq25.
