Scotts Posted September 20, 2014 Posted September 20, 2014 Hello team, So I'm the guy that won that L28 with N42 head and block on eBay few days back and I'm leaving from Sydney now to pick up (ACT.) Been a proud Z owner for 14 years but never stepped into this side of engine change. Don't know where to start but I'm hoping to put it in my 260z 2+2 as its has the L20 and want to use as a daily. Quote
Agno Posted September 21, 2014 Posted September 21, 2014 It bolts in exactly as your current engine would. The only variable would be the sump bowl position if your new engine came from anything that wasn't a Z Quote
Scotts Posted September 21, 2014 Author Posted September 21, 2014 Thanks Agno, It appears that it came from a 260C Auto and I'm manual. Not sure if this will cause any problems. Will assess it when I get home. Quote
nizm0zed Posted September 21, 2014 Posted September 21, 2014 you should be able to use the sump and flywheel off your old engine if needed. Quote
Impatient1 Posted September 21, 2014 Posted September 21, 2014 I was tempted to put a bid myself, glad to hear it's going into a car. I would have just used to learn something till I buy a z. Be interested to hear how it works out. Good luck. Quote
Six_Shooter Posted September 23, 2014 Posted September 23, 2014 Don't forget to put a pilot bushing in the crank for the input shaft support of the manual trans. Automatics don't have this, so it's not usually installed in the crank of an automatic equipped engine. Quote
Scotts Posted September 28, 2014 Author Posted September 28, 2014 Got her home! i opened the oil cap and had a very strong petrol smell.... Think I will invest in the rebuild books for the L28 and attempt my first ever rebuild. Quote
nizm0zed Posted September 28, 2014 Posted September 28, 2014 no better way to learn!! If i could suggest, maybe start a thread and document your rebuild. It'll give you your own space to ask any questions as you go along and give you the motivation to keep at it. If you need a hand, feel free to ask or PM me, plenty of people here are happy to give advice where needed. Quote
Administrators gav240z Posted September 28, 2014 Administrators Posted September 28, 2014 ^^ What he said, I'm doing the same thing with mine. Quote
