Hi Guys/Gals
i am after a pair of castor arms for my  240z i think 260z are the same,anyway will to pay a handsome price ::)  cheap is good and  i will cover postage if needed.
Cheers David
Sounds like you've understeer'd into a curb...
SW Motorsport do upgraded forged items that allow for more caster to be dialed in. Might be worth giving them a call.
Had a set, Not sure where they are, SWM are good and not expensive and give heaps of adjustment. Thats what I have got. give Stewart a call. ;)
Jeeze if i had known you wanted stock ones i would have given you mine! I thought you would have been after adjustable ones.
Hi jake
i want to make some adjustable arms using the cranked end part then my own bits as well.By the way what is the best model subi to get a diff out of,i'm looking for 4.44:1 ratio or there abouts with a clutch pack centre
Cheers David
I make my adj rods out of XE XF caster rods, heaps stronger and alot of fine adjustment thread
I think the diff you want is r180  WRX STI for that ratio
STI type RA club spec
Got to be specific here:
WRX STi Version 6 Type RA which is pre 2001, but post 1996 i think
It's a 4.44 ratio with a 4 plate mechanical clutch. There will be a big K on the top of the diff. I'll have pics of mine on my facebook page shortly.
