Kirby Posted April 27, 2014 Posted April 27, 2014 Time for another garage cleanup thread and drum up some new funds for my project. Everything is located in my storage shed in the Adelaide hills, but I will bring it down to metro Adelaide if you want to inspect/pick up, freight available PM please...whatever you want to do. First Up: Various body panels and drivetrain parts: Drive-shaft from my 76 2-seater. As is. Make an Offer Front Urethane Splitter. Picture on car here.Paint Stripped and good to go. $100 obo Front Aprons (2x). One is drilled to accept splitter above. Both are in reasonable condition, no rust. Make an Offer PENDING SALE Front Valence Corners (2x LH, 1x RH). One set (LH+RH) is in great condition been dipped and etched, light surface rust only and captive nuts are in good condition. 2nd LH is scrap metal but will come with the set $100 for the set. $75 for a side. PENDING SALE Axles from my 76 2-seater, were mated to a R200 long nose. Dusty but fine.$100 for the set obo 260z Drivers Door Marked as Coupe (2-seater). NOS in primer. Purchased from here. Now surplus to my requirements. See later post/photos; Late 260z Style. Taking Offers sorry ally drums are gone 5-Speed Manual from 76 2-seater As far as I can measure by myself ratios are 3.6:1, 2.25:1, 1.5:1, 1:1, 0.9:1, R3.3:1 Passenger Filler Plug, Driver side breather and Speedo out, 2 Drivers side switches, one is reverse other is D/C Bearings seem free with no flat spots, throwout is fine too, never had any dramas with the syncros while I was driving the car Might need a top up of fluid as its been leaking a bit out the rear yoke Includes cross member from 76 2-seater. $250 PENDING SALE R30 EFI Setup All there: ECU, Harness, Rail, AFM (with filter, elbow and other bits and pieces), Resistor block and Manifold. I'll need to have a hunt for the injectors as they are in a ziploc somewhere but are included Also included is a VL inline fuel pump and rear bracket (it mounts behind the fuel tank) Was running in the car with no issues on above engine, using stock carby fuel lines, never had any issues with surge (that I can recall) Harness is showing its age around the injector/water temp connectors, but that is the case with all these harnesses, nothing some love, electrical tape or heatshrink wouldn't fix I can include the thermostat housing with the temp sensor and thermotime switch I can also provide you with wiring diagrams and all the information you need you'd require to put this in a carby car (there are 6 wires to connect to your stock harness and 2 relays you will need to install and run it) Make me an offer! PM me on here to discuss. I'm based in Brisbane so you'll have to deal with my (awesome!) dad, but unfortunately he knows nothing about z's. Quote
Agno Posted April 27, 2014 Posted April 27, 2014 Hi Kirby, Can you please get your dad to take some photos of the driver's side door? In particular the interior side of the door, striker mounts and a tape measure to the interior lock-pop-thing position? Thanks Quote
Kirby Posted April 27, 2014 Author Posted April 27, 2014 I will get some more photos of the door asap. Quote
Moderators Zedman240® Posted April 27, 2014 Moderators Posted April 27, 2014 Gearbox sounds like a 280ZX 5 speed. Priced very well so it should sell real quick.. With the door, get a pic of where the door catch is so we all know if its an early or late 260 type; inny or an outy! Quote
Administrators gav240z Posted April 27, 2014 Administrators Posted April 27, 2014 Also interested in door, pending if 240z or 260z type. Quote
Administrators gav240z Posted April 27, 2014 Administrators Posted April 27, 2014 No problem. Might whip up my own door skins. I make it sound so easy . Will be consulting TAFE teacher on that. Rare spares also sells skins but will need to see if door shells are any good. Quote
DreamZproject Posted April 27, 2014 Posted April 27, 2014 GDMN! You have to be so super quick here to not get like 5 people jump in before you! !! Quote
Kirby Posted April 28, 2014 Author Posted April 28, 2014 DOOR PICS I've cross referenced with my pictures, it is indeed a late 260z (early 280z) style -- "innie lock". Which consequently is not right for my car anyway. There has been ALOT of interest in this part, so now I have provided the accurate information I'm going to accept offers for the door. 20% of the sale will be donated to AusZ website costs. Quote
Administrators gav240z Posted April 28, 2014 Administrators Posted April 28, 2014 Well I'm out because I need a 240z door. Quote
DreamZproject Posted April 28, 2014 Posted April 28, 2014 Lol I need a 260 door, but the early one like the 240!!! Quote
de5truction5 Posted May 13, 2014 Posted May 13, 2014 Kirby, your name sounds familiar, did you buy my gold candy apple 260z many years back? with a L28 injected Victor. Quote
