I know its not a 240/260
No, its even better  ;D
Few quick questions -
Was the engine together with the current parts at some point ? Do you know if the dellortos were tuned for this engine  ? Its not just a pile of parts that have never been assembled ?
Is the rollcage steel or alluminium ? Bolt-in or weld-in ?
Photo's of the diff / interior ?
"Custom" 5 speed - custom as in it is a 5 speed in a car that only had a 4 speed, or do you think there is something "special" about the box (close ratio / etc ) ?
How soon is "asap" for it to be gone ?
Dont worry about lack of or missing logbooks, that number on the sticker on the roll cage is the logbook number.
A future owner can trot into CAMS office quote the number, and pay for a replacement logbook.
Then its a matter of tranfpsferring ownership of lgbook, that way car can be run with the current as fitted cage, even if alloy.
Easy to weld tags to current cage to tie it into upper car structure.
Be interesting to find out previos owners as per logbook???
1600dave to answer some of your questions yes the engine was complete and the head and carbs were pulled down for inspection. The bores looks good but of coarse due to being a raced motor the tolerances would be very tight so a hone and deck on the block would be ideal before a reassembly. At the moment the block is in the car and the head and carbs are in one piece. The carbs were tuned for this motor and raced with them.
The rollcage is a bolt in aluminium cage with a cams log number. Mounts down to six points. The back two sections mounts to the rear parcel shelf and have a thick alloy sheet across the whole rear parcel shelf. The cage is surrounded with cage padding.
As far as the box and diff are concerned, i was told the previous owner was told "they had something done to them" but he could not confirm exact details when i took possession. Its def a five speed and gears feel tight but thats all i can say.
I will try and take some more pics today. The car needs to go ASAP as in yesterday so if no interest here i will list it on ebay for a 3 day auction with starting bid at 1500. I think based on parts alone this price is fair  ;)
Whack up some pics!
I'd be interested but gee, from Melb to Brisb, a bit of a trip!
The usual car carriers do not like non running stuff.
Dave 1600 you have first shot!
( get it, go on, you know you want it!!)
Yellow RX , what is the logbook number on roll cage sticker?
Vxxxx?
I can get info on it from cams database.
Car was first CAMS logbooked in 1990, and then again in 1991' it ran at some club level sprints and various hillclimbs in Victoria.
Original name in logbook is a
Marcel Toonen
Les Collins may have sold him a few items for this car
Car has had not a lot of use.
The Ebay ad has now been sighted by the wider Australian rallying community, suspect it will get a bit of interest!
With some 11 hours to go, bidding is at $3900
Turns out Les Collins /Dateally did rhe head, back in early/mid 1980's.
Thought it might be a good one!
What would be funny is if the winning bidder found this thread a month after he bought it  ;D worth every cent!
Haha yeah you would be spyarn'
Good thing this stuff doesnt come up in QLD more often, i would be even more broke.
Be interested to know,,, what did the time waster say or do?
I have mentioned it is still avail on a ACT based rally forum, you may wish to tempirarily join up, in order to post it up.
Based on what it has, i'd suggest at $1500 it is rather low priced. Put it up for 2500-3000, but mention you'll accept near offers. Most on there are genuine types
Good luck!
If i was closer i'd grab it, stick in a 2.4 and go club racing, alloy cage and all.
Btw a replacement for a "lost/missing" logbook at CAMas is around $70 and 10 minutes of time!
dat2kman
The guy thought i was going to reassemble the engine and get it running for him at the price he bidded. He was from NSW and only had a 6 rating on ebay. It clearly states the head and carbs are off the car. He didnt come on the date specified and was just making an excuse to pull out from buying it. He had a bad rating out of the 6 transactions. I spoke to him in the end and told him not to waste peoples time and to read the ad very clearly next time.
Thanks for the help advertising. I am happy with the auction setup at the moment. Id rather it just sell to the highest bidder for now unless a offer is good.
HKSZ
The head was pulled off for inspection only. It has changed hands two or three times. The last owner had no idea what was done to the motor and pulled it off to see the condition of the pistons, bores and head
nizm0zed
Thanks buddy i did have a few calls today but couldnt take em at work. just let him know after 6 is best
