Posted (edited)
Hi everyone,
I'm basically after all the pieces to go L26 EFI. I want the EFI bits from a 280ZX. Please PM me what you have to offer and we'll take it from there.
Kind Regards
Edited by 53-681
Privacy
Sam, what dont you like about what you are running now?
Bear in mind a old used heat cycled ex 280 ZX EFI system may need a fair bit of work to rejuvenate and get right.
They are good, but, when it comes to the total spend to get it right, ( unless you are lucky with a low mileage ZX to carefully remove it all from) ,,, you will be better off getting a ZX efi manifold, a set of VL commo injectors, a reasonable aftermarket ECU, a XF Falcon throttle body, set it all up with MAP sensor, and run the injectors at a lesser duty cycle, more tunable, and less of a head pharque!!
Hi Jason,
Approximately how much will all those parts cost and is there a reputable mechanic to perform the installation?
I wonder if Scoota G will do it??
Megasquirt 2 ECU's are fairly cheap on eBay (New)
I'm contemplating whether it's worth the hassle... Is it just worth purchasing an RB20/RB25 and getting that fitted in???
What do you reckon Scoota? :D
  • 2 weeks later...
i have a Low milage 190k engine complete , from air box , trap door throttle body and un molested manifold , all original + ECU
you can have the lot for $1200 engine runs very well
rgd's Darren
rgd's Darren
I suggest you get some comp figures for it be worth that much 190000ks isn't exactly low!
Yeah it's not low at all - What engine was it?
Possibly, going by his pic under his name, and his name, its a high mileage 1979 280zx engine.
Must concur on the thoughts of others re price, although if it had some internal mods/work done, then it'd be pretty fair priced!
Sam, where are you up to with your injection plans?
I'm still at planning stage trying to pick the right mod to proceed with Jason. I can either save up 3.5K and go tripple ITB's with a Haltech ECU orrrr purchase a 280ZX EFI kit from someone here on this forum. Seeming as my engine has had lots of work done to it in the past (high comp pistons, head, 280zx box, 260z auto diff, eletrics etc.) I think it's worthwhile investing in it and getting a good fuel system to suit.
I don't think I should skimp out on it...
My vehicle is currently parked in underground secure car park; I will just leave it there and probably catch the tram/bus to work...
Do you have any suggestions Jase?
Im in craigieburn and have a full set up, with a 280zx s1 and s2 SO let me know as i would swap for help with my car's efi.
The engine has sold for $1000 , as it is strong , never been rebuilit , and has 125 comp across the board !
But thanks for the shit canning guys , Nice for us new members to feel welcome on your forums ......good one !
But thanks for the shiver canning guys , Nice for us new members to feel welcome on your forums ......good one !
Dont think anybody was trying to shit can you mate. Nobody said its a shit engine or not worth the money only that it has high kms...
Most regulars on here know each other personally and just looking out for one another thats all mate. You will soon see we are here to help and we encourage new members all the time.
Someone needs a hug  ::)
(I can either save up 3.5K and go tripple ITB's with a Haltech ECU orrrr purchase a 280ZX EFI kit from someone here on this forum.)
All I can say is keep saving!!! EFI Throttle body's tapered bore with manifold set you back $4600 that's 50/48/45
And Haltech ECU platinum sport 2000 $2200 !! Just to give a realistic price. :o
Then add tuning on a dyno.........
+ manifold, + FPR, + fittings, + fuel lines, + fuel pumps, + surge tank, + wiring, + sensors, + air cleaners/airbox, + tuning...
For "bang for buck" as suggested prior, stock ZX injection manifold, new VLTurbo Commo injectors, XF Falcon TB, sucking through stock AFM, or run a MAP setup, aftermarket ECU.
You can only consume as much fuel/air as it can suck air.
Basic lo-buck setup, using modern ECU, tuneable to give correct air to fuels right through rpm range.
Cost? I have little idea, but
Manifold 50-100
Injectors x6 400
Xf TB at wreckers 50-100
Ecu 800-1200
Map 50-100
Fuel press reg 100-150
Incidental hoses plumbing pipes air filter etc 150-200
Tune/setup/dyno with wide band 300-600
Anyone care to add anything else!
Just threw in a bit of sarcasm for good measure. I thought it fit haha!
