- Yesterday
The Ratson
The Ratson
My Blue 260Z 2Seater
Late 260z 2+2 wiring diagrams
lpkadlec joined the community
I love originality, but for me... Upgraded Brakes Fuel injection and modern ECU Air Con (for hot summer days in Australia) Upgraded wiper and heater / fan motor. Makes the car infinitely more usable all year around.
