- Yesterday
PIN STRIPING
DBongard joined the community
My Blue 260Z 2Seater
BenjiT joined the community
That's a bit of a 'how long is a piece of string' question, as it depends on what you are planning to do... '73 onwards wiring looms have more wires and the plugs are colour coded and not available new. Unless it's been butchered, it's can be reused. FWIW the last '73 I did, we unwrapped the loom, inspected it, fixed any issues, then re-pinned the terminals and re-taped it. I do recommend fitting a new modern fuse box though: https://www.thezstore.com/product/4750/msa-fuse-box-short-pigtail-72-73-240z as the originals are almost always damaged in some way. If you are modifying it in any significant way, I would suggest you 'dry build' it before paint to avoid damaging fresh paint.
