260Z Gearbox Ratios - what are they???
10 replies to this topic
#1 Lurch ™
Lurch ™
  • 5,604 posts
Posted 10 July 2010 - 06:11 PM
Hi all,
I'm in need of a list of 1st to 5th gear ratios for the 260Z (71b) gearbox.
Does anyone have an ACCURATE list? The ones I've found on the net have been horribly inaccurate...
I'll update the info into the "What Gearbox's Fit" thread too ;)
#2 Lurch ™
Lurch ™
  • 5,604 posts
Posted 10 July 2010 - 08:36 PM
Apprently the Ratio's are:
1st:  2.906
2nd: 1.902
3rd:  1.311
4th:  1:1
5th:  0.864
Rev: 3.382
Thanks to Dimitri & his awesome little book!
#3 PeterAllen
PeterAllen
  • 1,325 posts
  • Tagline:Manana!
Posted 10 July 2010 - 08:49 PM
Slightly different to those stated in the Nissan Motor Corp 260Z Service Manual for Transmission type FS5C71B, published 1975.
1st    2.905
2nd  1.902
3rd    1.308
4th    1.000
5th    0.864
Rev  3.382
I don't know anything about it personally, just quoting the book.
#4 Lurch ™
Lurch ™
  • 5,604 posts
Posted 10 July 2010 - 08:54 PM
Thanks Peter!
There's not much in it, in either case :)
#5 Whittie
Whittie
  • 582 posts
Posted 10 July 2010 - 11:23 PM
I've got a tutorial to post as soon as I can find the pictures and put them on a server for fitting a 71c box and everything that is involved or not depending on the route you want to take.
What exactly do you need the ratios for? If it's for a 71c conversion I can flick you a copy of the tutorial. It's about 11mb tho, so can't post up here, I'll need to convert to text friendly version
#6 bluerat
bluerat
  • 540 posts
Posted 11 July 2010 - 11:40 AM
Other than a 240K 4 speed, they are the closest ratio's Datsun made in a factory box. Slipping in a 76 hey Lurchy? What you really need buddy is a LD crank if you want to go fast....
#7 Lurch ™
Lurch ™
  • 5,604 posts
Posted 11 July 2010 - 12:53 PM
Whittie, we already have an article on that subject:
http://www.viczcar.c...pic,3210.0.html
Hodgo, what ARE you on about? ???
#8 bluerat
bluerat
  • 540 posts
Posted 11 July 2010 - 04:58 PM
LOL sorry, looks like I was way off target! I was talking cams and wanting to keep it on the boil...
#9 haul
haul
  • 73 posts
Posted 11 July 2010 - 05:51 PM
This is what I got out of the book I have.                    Found this one , FS5W71B
  260/ 2 seat            260/ 2+2
1st  2.957:1            2.906:1                                                  3.321:1
2nd  1.857:1            1.902:1                                                  2.077:1
3rd  1.311:1            1.308:1                                                  1.308:1
4th  1.000:1            1.000:1                                                  1.000:1
5th  0.852:1            0.864:1                                                  0.864:1
rev  2.922:1            3.382:1                                                  3.382:1
Tony
#10 mossy
mossy
  • 1,770 posts
Posted 14 July 2010 - 08:22 PM
Even though I've rebuilt a gearbox before like the rest of my mechanical knolwedge its very limited, thats where I'm confused about close ratios, I've got an early 71a gearbox which pretty much fells like its in neutral even though its in gear so I want something thats a lot closer together between gears, is this what a close ratio is or am I way off?
#11 dat2kman
dat2kman
  • 4,031 posts
Posted 09 September 2010 - 08:31 PM
Tony
Not quite,
the list on the left is early 240 z 3 peice, also used in datsun Sports 2000's known as a 71A
the list in the middle is early 260z known as a 71B
the list on the right is late 260z,  some 280ZX pretty well all 240k's, early Skylines, most L20b engined bluebirds etc, it has the big gap between 2 and 3 also known as a 71B
there is a early 280zx box that has a 3.06 first, and some truck/commercial boxes have 3.59 first, this was done by altering the input drive/driven ratio gearset by a tooth or two.
The later RB type boxes are the sameratio ( except fifth gear) as the later 71B box, but with internal differences for strenght and other shizz.
