Blue Z
Everything posted by Blue Z
  1. Hi Katokid, A huge thank you, I now have new CV boots for reasonable price. Thanks Blue Z!
  2. Hi Z Fans, Just wondering if anyone has the part no. for the 300ZX Outer and Inner CV joint (4 bolt on the outside)? Or a good source to find replacement ones? Cheers Blue Z
  3. Hi CraigZ, Would you still like to take them?
  4. Hi 1000 plus club, The centres will suit about 77-78mm, it not perfect measurement with the plastic. Do you still want them? Regards BlueZ
  5. Hi All, I have the 4 x centre caps from some performance wheels, which no longer have. They are brand new never used. For a $10 donation to the VicZCar website they are yours, I will even look after the shipping within AUS. Please make a comment that you would like them and send msg of proof of donation and I will then ship. BlueZ
  6. Hi Greg, These guys have few options, I have never used them but would be my choice. https://technotoytuning.com Regards Blue Z
  7. Hi All, Good news I now have the bell housing off, I ended up breaking the seal by forcing in an window scraper blade. 1) As I have no shifter does anyone have a recommendation for a short shifter for the RB20 gearbox? 2) Any recommendations for the machining on the L series bell housing in Melbourne? Thanks Blue Z
  8. Any offers on the oil temp gauge considered, also happy to post it. Perfect to make sure your not cooking your oil. Blue Z
  9. Thanks Lurch, Looks like need a big soft hammer to open it up, as you suggest, it hasn't moved yet.
  10. Hi All, I have an RB20 gearbox and I have done the following: 1) removed front cover plate, inside bell housing 2) removed bearing circlip under cover plate 3) removed bolts from sandwich plate holding bell housing on The issue is that I can't take the bell housing off, have I missed something? BlueZ
  11. Air box and Filter now sold. Oil temp still available
  12. Hi All, Few pieces that I have in the shed: 1) Sparco oil temp gauge, thermal expansion type $30 (due to change of sump I had to change to electric sender type) 2) 90 deg 3" stainless bend and K&N filter $60, Filter needs a clean but otherwise fine. 3) L28 Airbox to suit 45mm Webber or EFI hardware ITB, $100. (Made by Gordon Dobbie) Location Eastern Suburbs Melbourne Would be open to a trade on a reasonable 260z 2+2 boot lid with glass. Regards Blue Z
  13. Hi Justin, Yes one with switch, yes O rings only from memory.
  14. Hi Justin, I had the exactly the same issue, just pull out the pressure differential switch and replace O rings. The O rings in mine had split and caused this fluid pumping issue. Good luck, Blue Z
  15. Hi Lurch and Dat2man, Thanks very much for the feedback, so based on this being 71B, I assume this will be the close ratio set for the gearbox? " L-Type: Only for FS5W71B Transmission type. HR31: Only vehicles before 8/87 Get this and all your JDM at RHDJapan!" http://www.rhdjapan.com/kameari-super-close-gear-set-l-type-fj20et-hr31-zenki.html Which would provide these ratios:- 1st: 2.624 - 2nd: 1.814 - 3rd: 1.360 - 4th: 1.000 - 5th: 0.813~0.93
  16. Hi Guys, Hoping that you can help and provide the gearbox ID number for this box? It was from a 280zx with 5 speed manual from about 1978. I am looking at one of the Kameari close ratio kits and just want to make sure I pick the right one for this gearbox. Thanks for your help, Blue Z
  17. Hi Z team, I have installed a new Arizona z car aluminium sump, the only issue is I was using a thermal expansion temp gauge and this no longer works with the sump. Does someone know a good electric temp gauge, one that fits in one of the top small Dashboard gauge spots for good price with online order? Thanks Blue Z
  18. Hi Lurch, Called MD spares, no luck, any other ideas? Cheers Blue Z
  19. Hi Lurch, Collets, I have the retainers. Cheers Blue Z
  20. Hardened Valve Seat?
  21. Hi Guys, I have been making process on my L28 build, I am looking for new set of standard valve spring lock retainers. Does any one know if any one stocks these in Melbourne off the shelf for a good price? Cheers Blue Z
  22. Hi, Just wondering if anyone has 1 x new ITM 87mm cast aluminium part number RY 6134-40 lying about? Or know where to find one? I bought a set of 6 about 1 year ago, unfortunately 1 was damaged during assembly, bugger... Thanks Blue Z
  23. Hi guys, Feedback has been really useful, I called Chris Bullen today and he is able to help out. I will call SWM on the retainers tomorrow, my shims will be higher than 4.25mm, I have previous thrown a lash pad out and would like not to repeat it. Blue Z
