Blue Z
Everything posted by Blue Z
  1. Photo's of the RB25 head with modified intake manifold. Cams, rocker covers, fuel injectors included. The throttle body is about ~90mm, would make a great base for high performance turbo machine, ready to bolt onto a RB30 bottom end. Valve seats were re-cut by crankshaft rebuilders along with surface of the head to get good sealing on the head gasket.
  2. Hi Guys, There has been a lot of interest in the parts, so I have provided an update on the status of the items, plus I was looking through the shed and found some more parts which I have listed up. Garage Clearance • RB25 Head & inlet manifolds, matched & polished complete with standard cams $700 • RB25 standard cams $50 • 2 X L28 exhaust extractors $$40 ea (pending payment) • L26 5 speed manual gearbox, $200 (Sold) • Heavy duty power Hacksaw (single phase) $100 (pending payment) • 2 X standard 280Z computers $10 ea • Davis Craig Electric water pump & controller a few hours use only. $150 • 2 X 260z radiators $25 ea (pending payment) • Set of 4 260Z original alloy wheels $40 (sold) • Set of 4 280Z original alloy wheels $40 (sold) • Pair of 206Z seats $40 (pending payment) Further Parts found in shed • RB30 Distributor $10 • 280zx electronic distributor $40 • 280zx air flow meter $5 • Aluminium L28 fuel injection manifold (smaller NA unit) and standard fuel rail $30 • 12v Electric Radiator Fan $10 •
  3. Hi Gareth and Dat2kman, One more question, what is the advantage of the RB20 internals in the 260z box compared to the FJ20t which according to the forum bolts straight on?
  4. Hi Gareth, Can you explain how the bell housing is modified on r32 gtst gearbox to suit the l28?
  5. Garage Clearance • RB25 Head & inlet manifolds, matched & polished complete with standard cams $700 • RB25 standard cams $50 • 2 X L28 exhaust extractors $$40 ea • L26 5 speed manual gearbox, $200 • Heavy duty power Hacksaw (single phase) $100 • 2 X standard 280Z computers $10 ea • Davis Craig Electric water pump & controller a few hours use only. $150 • 2 X 260z radiators $25 ea • Set of 4 260Z original alloy wheels $40 • Set of 4 280Z original alloy wheels $40 • Pair of 206Z seats $40 Shed clear out due to house move, all has to go. Located in eastern suburbs.
  6. Hi Pauly, I have a 280zx electronic dizzy that was setup with an aftermarket turbo system. If your still interested? Regards James
  7. Hi Mikey, I have the following parts that you might be interested in: 2+2 Flywheel 240mm clutch (pressure plate and friction disk) 260z Gearbox I am in the eastern suburbs. Regards James
