66 -
Everything posted by vspecrob
Hi all, Look for a good condition R200 with either 3.7 or 3.9 ratio's.... Cheers, Rob
Hi, Is the motor a Series 1 or 2? If it is a series 2, would consider separating the wiring harness? Cheers, Rob
Brake Master Cylinders 7/8,15/16 And 3/4 Clutch Master
vspecrob replied to 280zUSA's topic in Parts and Tools for Sale
Do you still have the Nabco 15/16, what Booster will it fit? Cheers, Rob -
Any of them carry an R200 diff, I am after the front diff cross member...
Hi Z ppl, Apparently this cross member has a bigger opening for an exhaust and maybe a little stronger than the factory 240z type. Cash waiting.. Thanks in advance... Rob
Hi all, I have a set of 260z stub axles which I am about to fit to my 240z with a new set of wheel bearings. My question is... Is there a thread somewhere on the forum that explains how to perform this task, and any tricks to make the process easier?? or Can anyone enlighten me on how to do it? I have heard of placing the stub axles and bearings in the freezer overnight and placing the rear casing into the oven on the highest heat and then fitting them together... Please help Cheers
Datsun 240Z Fitting Kit For An Sr20Det / 3" Stainless Exhaust
vspecrob replied to 24Ozed's topic in Parts and Tools for Sale
Still have the exhaust?? Where abouts are you located? -
Hi all, I have an RB25DET Series 2. How much power can the standard Harmonic Balancer handle? If I am not outputting more than 600HP @ the engine... Do I have to use a Ross Racing / Metal Jacket Harmonic Balancer for that power output? Thanks in advance!
Cv Options For 240Z With 450Hp (@engine)
vspecrob replied to vspecrob's topic in Brakes / Drivetrain Components
BTW, thanks heaps for everyones input!!!- 10 replies
- Driveshafts
- CVs
(and 3 more)
Tagged with:
I have just recieved an email back from the driveshaft shop, and they said their kit can hold 1000 whp!! I think we are pretty used to the yanks exaggerating a little... but at $1099 US and I'm only asking for under 500HP @ the crank... it's probably not bad value, considering SW motorsports, is offering something similar "unbreakable" for around $2400.... Hmmmmm Decisions... decisions....- 10 replies
- Driveshafts
- CVs
(and 3 more)
Tagged with:
Condolences Dimitri... I hope I never have to get rid of my Z, and it's nowhere near being finished...
Hi all, I am currently facing a dilemma, I building a 240Z with an RB25DET with an expected power output of 450HP at the engine (won't be more than 500HP) and I want to know what CVs are on offer or my options. I have spoken to a few, and I don't have much faith in the Wolf Creek items unless I get other advice that proves otherwise. I also spoke with Troy from Ermish racing and he explained the the CVs he supplied were good for 400hp, but no more. I haven't heard much of the "the driveshaft shop", they also offer a CV conversion kit... Any help would be awesome... Thanks in advance guys...
- 10 replies
- Driveshafts
- CVs
(and 3 more)
Tagged with:
With the BC's, are you now able to purchase different spring rates? Last time I checked (around 3 months ago) you couldn't get different spring rates just the 4kg F and 5kg R that they offer here in OZ. In the US you can get whatever spring rates you want!! We are so not spoiled for options, like the US are... just saying
I am going 4 spot calipers (I think 4 spot Hilux units) and rear disc conversion rear (US purchase), I have an R200 LSD with 3.9, obviously an RB25det gearbox... (might go brand new from Nissan - $2800 - This way I know exactly what I'm getting)... and I have the mounts for the engine and gearbox sorted also from the US. Still contemplating changing my drive shafts for CVs... Its an expensive exercise... Just not sure if the drive shafts will hold at least 400hp at the engine... I will still have a chat with the Enkelman though just to be sure? Any idea what Enkelman charges for the Engineers certificate?
RB240... I am doing the same conversion... And I have a 73 240Z... I will check with Enkelman and associates... I'm was planning on welding some longer rails from front to rear under the floor pan... And some stitch welding inside the engine bay and see if that was enough? I think I want the 240z chassis to be able to handle between 350 to 500 at the engine, but want to know what I needed to do to be compliant... Thanks guys
Does anybody know of engineers in the eastern suburbs in Vic, that has experience in 240Z or Zs? Cheers Rob
2 seater roof skin / turrets? Expressions of interest?
vspecrob replied to gav240z's topic in Parts and Tools for Sale
I need a roof, so I am keen to find out what the cost will be.. Especially if it falls under the $700-800 mark... -
Looking for a 240Z driver door in good condition...
Still available... 240 z left and right front guards with nose cones welded on no lights
[VIC] 260z front spoiler, dash, swaybars
vspecrob replied to shanec86's topic in Parts and Tools for Sale
Hi, Do you still have the Fibreglass Guards Alfa Motorsport $500 -
280ZX CV drive shafts to R200 3.9 LSD in a 240Z
Thanks Dat2kman... SWmotorsports, is quite pricey at almost $1800 for just CVs... Do you know if DR30 CV's are a direct fit? -
Cheers David, With the amount of power I will be wanting, I'm wondering if the uni's will be fine... There is talk of vibration in "uni's", but whether its a pain in the arse... no idea.. if it's worth going CV's ... Wolf Creek ... maybe ... not sure.. $900... So therein lies my dilemma... More reading/research, obviously.. -
Help Please... Can anyone tell me if I can use the 280ZX half shafts (CV's) in a 240Z with a r200 LSD 3.90 diff? Is there too much work for this to be adapted to the 240z? Does the 280ZX have the four bolts to attach to the 240z? If not, is it just better getting drive shaft (uni's) fitted? Any other options would be appreciated Just to help those who need a little background to help me, I am fitting an RB25det with between 350 and 400HP at the motor is what I'm planning (That's the plan) Cheers
Hi, Do you have half shafts to suit these from R200?
260z parts and roller all got to go
vspecrob replied to EMPRACING's topic in Parts and Tools for Sale
Hi, Do you still have the rocker covers?
