well i changed my mind and went external for the pickup ,there was no room in the sump so it was lots easyer to go external ,so i tapped the oil pump for dash 10 and made a hose to the sump ,and on the inside of the sump i made a pickup to -10 and welded it in the sump .... lots of hard work
it is running bike carbs and its a kit you can buy from the UK. The manifold is really nice i will post a pic tomorrow.
The dato cranks are very good and there a good option but the scat crank is a good thing for the $ - its fine to 8000rpm.
People have been using the dato crank for years and they are much better than the ford crank and most likely the scat one too.
hi Lurch
iv started work on the esky, work on the head is very full on, heheh its know datsun but it will do
specs on the 1600 kent
new scat crank
60th race pistons
formula ford head
custom inlet manifold
all new valves and springs
and lots more will keep you up dated as i go
very easy he a nice bloke i have some turbo bits or i can build you a turbo set up for a L28 or i can build the hole thing for you give me a call or pm
update time
i have the short motor built . will start putting the head together tomorrow now all the parts are hear, the specs on the head have changed , it now has cosworth springs and ti valve retainers from tomei good for 10,000rpm and 35psi and the cam specs are now 11mm lift
