d3c0y
Everything posted by d3c0y
  1. Cool story bro.
  2. d3c0y
    L28T build
    ...and slacking off at the gold coast.
  3. Awesome info! Any idea what sort of HP this set up could hold? How much was the total all up, Machining + Parts? I'm thinking (in regard to my application anyway (350hp)) if 4140 axles are $400 + New CVs + Machining it's going to have to come in close to $1000 anyway?
  4. Needs more attachments and vents
  5. Year/Model: 1973 240Z Suspension: Standard, king springs, koni red. Body Modification: rear fenders rolled Comments: Fits easily, needs lower springs in the front Rim Brand:Rota RB-R Rim Diameter:16 Rim Width:8 Rim Offset:+4 Tyre Brand:Various second hand tyres Tyre Width:225 Tyre Profile:50
  6. Thanks juz0 but i'm not a big fan of those housings. Scoota: I had a look at them when i had the car and they were pretty cracked so i figured they wouldnt be any better than mine but i guess it's worth a shot. Thanks!
  7. If you are still wondering the badge for the back is the same as the ones on the front fenders.
  8. Why dont we get them delivered regular sea freight - will take around 3 weeks but would be that much for the whole 5 kits and then send them out once they get here?
  9. I'm still keen on a GB
  10. Top job Scoota!
  11. Hey Guys, Chasing some 240Z Front Indicator/park light housings. Don't need the lenses - screws would be handy though. Cheers Jake
  12. You really have to ask at what point the engine stops being an L and you are doing the same thing just going off and buying an S54 BMW I6 or something else?
  13. N/A S13 CA18DE cars were the only ones that had R180s from what i read. There are also different diameter shafts and i think this is LSD vs open diff (different axles). I think S13 axels are longer as the S13 has a wider rear track than the S30. FWIW i found some things saying 27 spline for S13 but i found more saying 29 spline so i gave up. 280Z and 260Z are all 25 spline from what i have read and i think K series S12 diffs are 25 as well. Cozza is your STi diff in your car? TDS just need that measurement and i think it's one of those things where you just have to pay the money. At least you are saving $500 but no having to buy stub axles.
  14. That is one tidy car!
  15. It's amazing you could be bother even clicking the post button. At least in the other thread you could be bother writing it was in sydney...
  16. Yeah i have subi 4.4s coming in my next container. You can even just swap out the ring and pinion into your diff if you want. Are you currently running an LSD?
  17. I have these - never fitted PM me if you are interested.
  18. It looks like it's running the following specs: -LD28 Crank -KA24 flat pistons -46mm inlet 38mm exhaust -.520" lift cam 76 Tomei All pretty standard stuff to do to an L. This head is cam belt driven from the factory and there has been a ton of work put into it to make it work. It would be interesting to see if it could run a cam with around .600" lift because it looks like the head has been clearanced pretty extensively already. Maybe that setup with the lifters is better for high RPM running? Sounds a lot smoother with the different valve train when it's running It's running 55 Webers with 53mm venturies which is pretty overkill for what i think that motor will make HP wise. It's definitely a cool motor would love to find a hp figure for it. 300-320hp maybe? It's also got acrylic 1/4 windows which is cool.
  19. Using the RB20e head you are sort of making an LY. You have to wonder if its like the Z (ie Z18 - Z24) heads though which were apparently not great for racing applications because you cant fit big valves in them. Had a look and cant find any info on valve sizes for stock or the one in the link.
  20. Haha i immediately thought the same thing!
  21. Yeah i agree Richard. My point is that those gears must be realllyyyy short for you what speed are you doing top of second? I thought it was common to put taller first and second in even with a 4.11.
  22. So how do you even use 1st and 2nd gear?
  23. how about a 4.4 R180 LSD out of a subi i will have one here in september?
  24. d3c0y
    the last engine
    Oh boy! It's here.
  25. FWIW these will require at least a 35mm spacer to fit on most S30s.
