Time for an update!
By September we'd checked fitment of all the parts on the 240Z so the 'dry build' was complete, so there was nothing left to do but pull it all apart and prep it for high-build primer.
Annoyingly my painter decided to take a month off from Mid-September to Mid-October, so the project stalled for four weeks, but once he was back we could begin.
My painter cast his critical eye over the whole thing, then once he was happy the WHOLE car was dry sanded inside and out with 240g soft pads, prep-solved, masked up and tinted high build primer was shot at the body & panels.
With all that done and the primer dry, the body shell and front guards was back-taped, so the underside could have stone chip applied.
We spent a LOT of time on the underside of the Z to dress any of our welding repairs and also fix any of the average work done by the little Japanese man on the production line in Yokohama...
As we wanted to do a 'better than factory' job of it, the underside frame rails are also masked off so no stone chip is applied to them - this makes for a more atheistically pleasing look.
The seams are then seam sealed, then the paintable stone chip is applied:
And the inside of the guards:
This whole process of masking, then de-masking takes bloody ages...
But it's all worth it, because next the ACTUAL colour is applied!!!
When I first received the Z it had been media blasted and all remnants of the original colour were gone - along with any paint code sticker.
However not EVERYTHING had been removed and Epoxy'd over - there was the remnants of an original grommet for the fuel tank vent pipe - still holding on for dear life - and when I carefully peeled it back...
YES!!!
I consulted the factory colours for 1970 and there it was: Nissan 907 Green!
So that's what it is being returned to.
The body shell was then prep-solved, seam sealed, primed and Direct Gloss colour was applied (wet on wet) to the underside of the body over the stone chip, then the engine bay and cabin.
All I can say is that it looks bloody amazing - even straight off the gun in DG!
Needless to say my painter is a legend.
I'm stoked and Tony the owner is over the moon to see colour on it finally!
Now we start bolting the driveline in to make it mobile...
