Showing content with the highest reputation on 04/20/2022 in all areas
  1. I like that the BT model has an anti theft capability via a PIN code. Edit: Also the option of a rev limiter. Sounds like a very good option if you are considering an upgrade or should one just stick to a High Energy Bosch Electronic distributor??
    1 point
  2. Hi Munters, Back when i posted, i was in a bit of a fix with the car not running and upcoming registration inspection required.. It didn't help that i had changed a bunch of critical components at once.. try as i could i couldn't get the original map i posted to run the car.. strange as the mappings were not too dissimilar now the car is running happily on the 2nd curve, i can look at re-introducing the anti-stall dip knowing i am starting from a decent base.. i was impressed with the original thought behind this dip, so i would like to introduce it again would love to know how you get on with the manifold vacuum install.. There seems to be some real benefit from it, and it would be easy to do on an SU setup.. however i have not found a definitive posting on how to achieve this with the triple weber manifolds.. keen to see your curves (with engine setup spec's) once your done!
    1 point
