professor229 Posted January 6, 2013 Posted January 6, 2013 Good Morning: I am going to try to make this short without all the interventions I have tried on the car, but to make a long story short, when I bought it, the seller started it and drove it on the trailer and that is the last time it has run. Through a lot of research and personal messages to some members, I know that it is electrical in nature (no spark at the new plugs) and that the ballast resistor circuit works (key on run), but the start circuit that bypasses the ballast resistor when the key is turned to start, does not produce any electricity to the coil (starter motor turns fine). There are a lot of variables to look for, but first I want to bypass them by running a wire from the positive side of the battery, to the positive side of the coil (bypassing the ballast resistor), and then turning the key to start (hot wire the car). It should run, and then I would immediately remove the hot wire when the key is released to run on the ballast resistor circuit. If I succeed on getting electricity to the plugs and the car stated, then I can start tracing back the problem (IE broken wire, bad connection, bad switch, bad coil, open thermal relay). I can also check to see if the coil is working properly (new one on order already). This is a 1971 240Z manufactured in August, so it is a series two car. Has anyone hot wired their car and if so, the do's and don'ts would be appreciated. Thanks... Dennis Quote
dat2kman Posted January 6, 2013 Posted January 6, 2013 Pull off distributor cap, put a socket and ratchet handle on front crank nose pulley bolt, rotate engine, look to ensure points gap is opening/closing. If so, goog, if not adjust so that on full dizzy cam lobe points are at 40 thou ( 1 mm) Now look inside dizzy cap, make very sure it is coean, no moisture, no carbon tracking. If suspect replace. Another simple thing, the condensor on side of dizzy can simply just fail, replace. Go over electric checks, crank engine with a spark plug wire disconnected, hold with insulated pliers, look for some spark, if so, your ignition system is good. Check static timing, no 1 cylinder points gap should start to open at around 10-12 deg btdc, the marks on front pulley will show this. Other possible, the electrical unit at rear of ignition key barrel may have failed ( contacts) If all ok, and in order, look at fuel delivery next Quote
Moderators Zedman240® Posted January 6, 2013 Moderators Posted January 6, 2013 Your ignition switch may be at fault also. Best tool is a good test light; check for power at different points. Quote
neRok Posted January 7, 2013 Posted January 7, 2013 Power always goes to the ballast, and it sends ~9v to the coil. To aid with starting the car, full 12v is sent to the coil via the keybarrel. This is because when starting, the volts may drop a little and you might only get 6v out the ballast. You can just take 1 of the wires off 1 side of the ballast and move to the other (so both wires are on the same side), so then the full 12v is passed to the coil at all times. Quote
620Z Posted January 7, 2013 Posted January 7, 2013 My guess is the key barrell. Zeds are natorious for this. Sometimes works, sometimes doesn't. I would start there. Quote
professor229 Posted January 8, 2013 Author Posted January 8, 2013 First, thanks to all who replied.... I have tried several of the suggestions and need to find the time to check out the remainder of the ideas presented here. We did have some major success yesterday, and like always, two steps forward, three steps back but we did isolate the ignition problem... well, let's just say we narrowed it down... but we also failed to observe a few things too.... A friend came over to help because one guy cannot turn the key and run a test light at the same time. We did hot wire the car (leap of faith kind of thing). I never thought about moving the 12 volt wire at the ballast to the other side temporarily (we had already tested the ballast resistor circuit; 9 volts so we knew it would run but...)... so we ran a wire from the battery to the positive side of the coil and turned the key to start with the test light on the negative side of the coil first to make sure we had a circuit that far. We did... good spark... so then we moved on down the circuit towards the motor... wire at the dizzy leading in and that was all good... but still no fire from the motor, so pulled a plug wire, and attached a new plug to it and grounded it... and turned the key to start... LOTS of spark there too... So two things come to mind at this time... as someone pointed out, fuel delivery, and the ignition circuit for the 12 volt circuit has problem before the coil... But we wanted to get the car to run, a little bit at least, so I changed all the plugs... We had primed the carbs early, and that gas was built up on the plugs so we took that variable out and just put in new plugs. We sprayed a mist of fresh gas in each carb, closed the choke, and turned the key... and it ran... for about ten seconds... we repeated this twice, with the same result. So now we are down to fuel delivery... pulled the hoses leading to the carbs and turned the key... fuel flowed fine from the pump... so now there are two theories here too. One, we were not patient enough and should have tried to prime the carbs a couple more times to get enough fuel to the float bowls... or the floats need to be removed and possibly the needle too..... Before I go on, and I will research this on You Tube and my manual a bit, but can I remove the float bowls to see how much crud is in them without removing the carbs completely? I could then also see how much fuel is in the bowls... I might want to order out two carb kits before I try this though... new gasket on the float bowl might be necessary... hate it when that happens... OK... so now we know the components from the coil on are fine... the timing is OK within reason.... and I will do as suggested and check the continuity back from the coil to the switch.... and it was good to know that the switches in these were notorious for failing..... So, what did we fail to do? The 12 volt circuit needed to start the car, runs through the tach... Neither one of us checked the tach to see if it was operating at all, when we had the motor running for the three 10 second bursts... I think excitement overwhelmed reason at that point... But if we had looked, it would have helped in tracing the problem location of the circuit; at least cutting it in half if the tach worked or not... open circuit before or after the tach kind of thing.... Something for next time... Again, thanks for all the help and suggestions. I am leaving the ignition system alone now for a good week with the knowledge that we can get the engine running properly (it sounded excellent) and I have to spend the remainder of this entire week on the body work and floor project. I made great progress again on that yesterday too.... I hope I didn't wear out my welcome here... but this car has been modified heavily from previous owners, so much of the time, I find myself researching how the car should be.... and I know for sure, that whoever repainted the car will never be known as a meticulous painter... nobody can possibly be that bad taping the weatherstripping around the windows!!! or simply removing some assemblies instead of trying to paint around them! Thanks again... time to look again, at the You Tube videos on the SU carb... some good, and some well, not so good and so it goes... Enjoy your day... Dennis Quote
neRok Posted January 9, 2013 Posted January 9, 2013 I just went through the same fitting up new carbs (new to me, actually secondhand) . If you have the round top carbs with the fuel bowl on the side, its just 3 screws and you take the lid off the fuel bowl. My needle vavles needed replacing, they were not closing. Yours might be stuck shut? You can just pour some fuel into the bowl and put the lid back on, new gasket doesnt seem 100% necessary. Its not hard to pull the rest of the carb apart and clean it out. Take the 3 or 4 screws out that secure the 'bell' on top. Lift it straight off (there is a big spring under it, which will push against you). Then pull the piston straight up (it has the needle attached to the bottom, so pull straight not to bend). Now clean everything, reassemble (things only go together 1 way), put some new oil in the dashpot (whatever you have, tranny fluid or engine oil etc) and all done. Quote
Moderators Zedman240® Posted January 9, 2013 Moderators Posted January 9, 2013 To diagnose fuel problems, best thing I found was "Aerostart". Spray into carb / throttle body and if fuel system isn't working but ignition is fine, car will run as long as you keep spraying! Quote
zeds4ever Posted January 12, 2013 Posted January 12, 2013 For what its worth ,when I start my 260Z up after about a weeks break I find I have to let the elctrc pump run for about 30 secs turn the motor over a few times to get some oil pressure then give about half choke so that the motor doesn't rev to hard when it starts up, let it run at about 1500 revs for a cple of minutes to warm up to 170f, Find it runs fine after going thru this procedure each time. Might add that the motor is a 280l with elctrnc dissy & twin 1 3/4 SU'S. Regards: Alan. Quote
Daedalus-Z Posted January 22, 2013 Posted January 22, 2013 Hey Dennis, regarding your comment about the Tacho, you should be right even if the tacho is stuffed. There's a loop of wire running through the back of the tacho that does indeed need to be connected for the ignition to work, but even if the tacho itself is buggered the loop should still be fine (it's literally just a few turns of wire). My only comment on ignition would be, make sure your plugs aren't too cold. I had issues with getting my 260 started at first, one of which was the plugs CONSTANTLY fouling from the slightly stuffed carbies. Hotter plugs solved this and gave me enough actual run-time to get the thing into some semblance of a tune. If you're using round-tops (assume you are as it's a 240!) it's not very hard to remove the float chamber lids and have a look inside. What might also be useful is checking the float level. There are plenty of instructions floating around (http://www.zcarz.us/TechnicalInformationPageCarburation.htm for one) for doing it in various different ways, but basically you want to take off the top of the carby with the piston in it and have a look down the top to see where the fuel sits when you crank it. It shouldn't need to be perfect to get the car to start with if there's no fuel or fuel is pouring out into the carby body, then you might need to adjust the float level. The carbies are quite simple, if you're careful to not lose anything you shouldn't have any trouble disassembling them to clean and inspect. Quote
