C.A.R. Posted December 8, 2012 Posted December 8, 2012 Rob @ Robco Engineering is having a parts cleanout: L28, Blueprint Rebuild Approx 8000kms ago 1mm O/Size Duralight Pistons, ACL bearings, new timing chain & guides $1500.00 L26, 74deg cam, E88 head, Steel Flywheel, BMW Front pully, 124kw @ rear wheels, Approx 2,500kms $2500.00 260Z gearbox, 2.98 first gear, Totally rebuilt with new bearings & sycro's, plus other modifications 3000kms old. $2500.00 2 R200 Diffs, both 3.7 ratio, All new seals $150.00ea LD28 Diesel Crank, as new condition: $1000.00 6 new H-Beam Conrods, 133mm centres, ARP bolts: $1000.00 Good cond. 240RHF guard: $220.00 Font guard lower repair section: $100.00 Other misc parts: Fuel tank parts Radiator heater unit Air-Con unit Good bonnet Headlight Buckets - call for prices. Contact Rob Crichton: Work: 9775 1413 Mobile: 04133 12649 Quote
Agno Posted December 10, 2012 Posted December 10, 2012 ... must not buy L28... aaaarg so much excellent value! Quote
