Awesome thanks! Looks really good. I just bought a set of 15 x 8 zero offset and trying to work out tyre sizing. I have stock suspension and will likely just use the king springs to lower a little.
Do you get any scrub and have you had to roll guard lips at all?
I havent had any scrubbing yet mate
Hi, did you change the cam for the triple mikuni or stock l26 cam?
It is back to round top sucarbs right now but when it had triples I put the smallest choke size in them I could for the stock l28.
I have a set of triple mikuni 40phh too that i have yet to install. Not sure if the performance will be good for stock L24 engine without changing the cam.
LockLock it all comes back to the set up. Are Triple Mikuni's better than Twin SUs from a performance perspective? Generally speaking yes. But unless you have all the components matched together to get the most out of them then there is no point installing them. If set up correctly the Mikuni's will be better overall.
Apparently this is a stock L24 motor.
https://www.youtube.com/watch?v=4FqYkdliZFE
Channel is here: https://www.youtube.com/channel/UClHMvCcDDaBXz9TMsu4MXiw
