hi guys just wondering how hard it is to put Rb25 into my 260z and what compactions i will come across?
as I'm getting an Rb25 motor and gearbox
Why would you want to put a RB 25 in there???????
253's are WAAAAAAAYYYYYYYY better motors, especially for a dodgy slap together burnout car.
Been covered, search.
Hint, gearbox crossmember....
Very easy conversion to do. Engine mounts / gearbox mounts are available from lots of different places (this forum and Castlemaine Rod Shop) Sump / oil pickup is probably the hardest parts to find unless you modify a GQ Patrol unit. Everything else is pretty straight forward.
cheer mate i look into it
@nizm0zed
pull ya haed out ya arse and stop being an up yaself wanker coz it going to still be dogge with an rb25 in it!
As dimitri said, the RB should be a nice conversion. There a mountains of info on numerous websites, including this one.
Hmmmmm Ive been away on holidays for 3 weeks , whats with the 253 ? have I missed something.....Alan is usually a gentleman  ???
well that just friendly banter ...... the Rb25 is a good little donk but be careful it will cost a bit, lots of mods to make a efi run in a zed ,,,,,but lots of fun and like zedman said there are lots of parts u can get to do the job, and the hard part is the sump and pic up and making the gear box x member and tail shaft  but all these things have been done and there are lots of pics on the site
Checkout Jamo250Z's build thread.  He found that for a street car, if you sit the engine in the right spot then you can use part of an R33 tailshaft (front half I think from memory?) and just change the yoke to go onto the diff.  It's sits the engine a little further forward than what would be ideal for balance though.
As Pete mentioned, there's always a fair bit of work converting a carby car to EFI.  It's handy if you're good with wiring or know somebody who is.
