hmmm I've got a small problem with my indicators....
my right hand indicator started to go a bit funny over the last week (would have to try a couple of times to get it to work), LHS is fine. my RHS indicator now doesn't work at all, however the relay clicks (albeit slower than usual) and the globe looks ok....
any suggestions? I think I'll rip into it before work today (been a while since I've got to play with the zed.)
Huw
well....I've got the right indicator working again....but the left is now doing what the right was doing! think I'll just clean all of the connections and put it back together.
any more ideas?
Huw
  • 2 months later...
I've got the same problem Huw had. I've found the issue on mine is the actual switch the indicator "lever" comes out of. I've found you can unplug the four leads that plug into it and unscrew it from the half that has the lights/wiper controls. I've pulled it out and plan to replace it when I get back from a week away.
Anybody a spare to sell?
I've found some more info on the indicator switch that plays up. In addition to this problem I have also recently experienced that lights go out when changing from hi to lo beam. I figure this is closely realted to the switch issue as I beleive there are some contcts located just below the switch that is the hi low beam swicth that plays up. My plan is just change the whole unit over but I beleive there is an indicator switch rebuild kit available for the 240, not sure about the 260. I've copied much of the thread below, also a link to the original thread for those that might experince the same problem in future, (note all pic's shown on the original thread), a pic of the dodgy switch below:
http://www.classiczcars.com/forums/showthread.php?t=9944&highlight=indicator+switch
allzed240au
Registered User
any one had trouble with there indicator switch i have replaced mine once and the second ones now stopped working on left hand side
anyone had this problem and found a fix or replacement if not any aussies got a spare they want to sell let me know.
Mick
Mick,
Try a squirt of WD-40 or CRC. It's worked for me several times.
11-05-2003, 09:12 PM #3
Mr Camouflage
Datsaholic
I had a problem with my turn signals. It turned out to be a worn assembly/switch on the end of the indicator stick. I would only indicate right if i pushed it really hard.
So i pulled it out the whole assembly, loosend up the screws that held the switch on the end of the stick and repositioned it.
Now no left or right.
What had happened was the plastic bush type thing that switches the switch has worn out, so that when you push the lever it rocks a bit and doesn't fully push the switch. (i think the switch wears internally also, and that combined with the lever not pushing the switch far enough up or down means no indicators).
So i wedged a thin piece of plastic between the metal part that holds the lever, and the plastic bush thing. This takes up the extra play in the assembly that makes up for the worn part.
Now it works fine.
You should also adjust the switch position by loosening the screws that hold it in plase and repositiononing it so that you get both left and right contact happening.
11-05-2003, 11:10 PM #4
Victor Laury
Super Moderator
Mr C,
Excellent photo! Please put that in your gallery, with "reference electrical switch signal turn" in the Keywords field.
11-06-2003, 01:20 AM #5
Daniel
Registered User
Excellent photo indeed!!Notice at the bottom of the photo that long white connector.Thats the hi/low beam. 4 pieces of the fiber board "feet' go in those slots. notice the right side is brown(foot is there) see on the left the shiny contact(foot lock missing). It's not long for a burn out.That contact should be above that slot.You may increase the life by trying some jb or such to hold it back in place.Or better yet I think that rivet at the top is hollow.Make a base to fit the white housing bottom and maybe twist of wire or small tieWrap.Look good fellas,This is the number one headlight killer.If your isn't broken I would fill it with something as those feet are brittle.
11-06-2003, 10:06 AM #6
240 in OZ
Registered User
Call Warren at All-Z Parts and he sells a kit that allows you to rebuild the switch in question. Genuine Nissan parts.
11-06-2003, 07:48 PM #7
Mr Camouflage
Datsaholic
Quote:
Well it wasnt missing, just had slipped down a bit. I pushed it back up. Might wrap some eletrical tape around it to stop it comming down again.
11-06-2003, 08:53 PM #8
Daniel
Registered User
What is warrens phone#? Thanks.Also those things just done slip out. I'm thinking if you shove a needle under the fiber on the bottom across the slots and clip off the extra (left and right sides).Then put some silicone to hold it in place that would give great support and take the stress off the old fiber feet.
Contact details for All-Z Parts in Sydney
Ph 02 9484 8257
website: www.allzparts.com.au
Hope this helps you out.
An indicator-switch rebuild kit you say? This I have to investigate!
(I too have the 'indicate-right-damn-you!' problem with my switch)
11-07-2003, 09:03 AM #11
240 in OZ
Registered User
Ben
Investigate away. I bought one a few years back from Warren. It includes the metal internal switch of the left/right select indicator and also the plastic high/low beam switch (common burn out problem on the z).
Hope he still can get them. Let us know how you go. If he doesnt have them PM me and I will bring in the Nissan part# for you and you can try your local Nissan dealership directly.
Regards
Joseph
__________________
11-26-2003, 02:10 PM #12
Ben
Registered User
Part number 25545-N3600
Still on the master parts file, ex Japan $61AUD. Beware the description is 'screw'
Joseph, many thanks for the part number - I owe you one!
11-26-2003, 05:11 PM #13
BillD
Registered User
This seems like a real winner. Can these be obtained in the states? Chloe??
11-26-2003, 06:28 PM #14
sblake01
Datsunologist
The part number (25545-N3600) comes up as 'Switch t/s' in the Nismoparts.com database. It shows a price of $21.23 plus shipping. In my experience, this doesn't mean that it is still available through them. You would still have to call to check availability. Their parts database is useful also for inputing a known parts number to get a description of the part.
11-27-2003, 04:20 AM #15
240 in OZ
Registered User
Hey Ben
Thats great news that the part is still available, bet it will save a great deal of otherwisw defective indicator switches out there.
Others, keep in mind that this kit will only rebuild the 240z style switch as far as the indicator selection switch goes. Seems like the 260z switch has a slightly different "moon" shape to the indicator select switch (see the metal "moon" shaped piece in Bens photo above). All else is usable between the 240z switch and the 260z switch.
BTW Ben, Im glad to help out after all the help that you have provided me over the years that we have been in contact. You dont owe me one, more like I now owe you 99 from 100 ;>
Let us know when you are fully street legal.
Regards
Joseph
__________________
09/71 Datsun 240z (Semi-retired)
1969 Datsun 1000 (Daily Driver)
11-27-2003, 04:38 PM #16
bula_rav69
Registered User
I have the same problem with my "76 260z But has anyone had there headlights go out completly when switching from high beam to low beam? this happens to me at times and it's a real safety concern!! Luckly the lights come back on when you switch it between high and low but a real worry!! Also when driving in some wet weather the other day ( with head lights on) I noticed a burning smell and saw some smoke come from behind the stearing wheel! I switched the lights off and luckly the zd is ok and hasn't burnt to a crisp! There must be some high AMPs runing in that low beam high beam switch! I must have a short in the wiring! has anyony had the same problem???
Ahh sweet, im glad you mentioned that, mine was doing the whole turn off when going from high to low and had no idea what it was. Ill fix it when i get the caar back together.
cheers
  • 7 years later...
