Hey guys,
Thought you might find this interesting:
Price to import these HPC coated from states is $475.
http://cgi.ebay.com.au/Datsun-280Z-240Z-N42-P90-E88-Ceramic-Coated-Header-NEW-/400212390005?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d2e847075
Price to buy similar headers and have them coated here is $300 for headers and $280 (cheapest quote) for HPC coating so $580.
http://cgi.ebay.com.au/Nissan-Datsun-240Z-260Z-6cyl-Petrol-Extractors-Header-/260773295282?pt=AU_Car_Parts_Accessories&hash=item3cb74cb4b2
I know the two piece american one's are gonna need some kind of clamp, which won't look as good as a seamless design, but I can reduce shipping on the American ones by about $75 if I buy a lot of items, meaning it's $180 cheaper to buy from US than AUS at the cost of a couple little clamps on the exhaust!
Thoughts?
Steve
only problem is that if you want a 2 or 3 bolt flange plate you will have to grind off the coating and weld which if not recoated will rust, slip joints i find do just that slip or leak even with a clamp, certainly a lot cheaper, takes 10 days to send them off for coating and sent back here anyway, makes you wonder how they can produce them so cheap , lots of them probably
The USA ones look much nice... All the cheaper ones we get in australia are fairly crap!!
your not wrong there, nicest aussie made pipes i found were genie they are mandrel bent ,but the primaries are too short, the hm header pipes have a longer primary and secondry but the pipe diameter is too small and require a lot of finishing off work and are not really designed for hi power L28 engines without a lot of work first
>:(  Had a set coated at Guildford ( Sydney) bout 12 mnths ago, noticed that there is indications of surface rust coming thru on them as I have a vented hood set up & naturally water enters.
        Regards : Alan.  :D
how bout you support the local economy where possible.......
cheaper in china if youre worried about pennies now......
but if your worried about all of our futures, buy australian where you can......
china'ism is becoming the death of already advanced society and our government are fucked in the head allowing free trade,
what happens when china say fuk u???????
after they already consumed all our natural resouces????
Thanks guys.
Nato that is way beyond the scope of this thread, please feel free to make your own thread elsewhere on that topic.
I'd appreciate it if we kept it on the topic of HPC coated headers please.
If I bought the US headers and had a flange plate welded on do you think re-coating the flange plate would be expensive dazzed?
Cheers,
Steve
yep,
but why bother,
the HPC coating around where a flange would be, somewhat a metre or so from the high heat area would be insignificant loss of anything
Do it yourself may be an option.....lots of heat req'd
