zeds4ever Posted April 10, 2011 Posted April 10, 2011 Mate suggest you sort your carbie's out first . Would liken it to having your shoe's on ass about & trying to run in them. Ok while your standing still if you get my drift. Then go from there. Regards: Alan. Quote
luvemfast Posted April 10, 2011 Posted April 10, 2011 Carbies first. But still read the plugs anyway as you may have a problem anyway. Quote
salty Posted April 11, 2011 Posted April 11, 2011 if the front carbie is the cause for the low compression, then #3 wouldnt be that high and carbies dont give compression. if you can hook up a vac guage to the front carb with the engine running that might give you an indication of the problem. my guess is head gasket as compression is low between 1 an 2 or broken rings on 1 an 2 Quote
bullzed Posted April 11, 2011 Author Posted April 11, 2011 The reading doesn't matter. It's the difference in the readings that matter. If they all end up much closer in value, it indicates a ring failure in the cylinders that were already low. If they all go up by about the same amount, it indicates a valve issue. Just give each cylinder a good squirt and give it a try. Ahhh okay. It's a comparative measure, makes sense now, cheers I've got a VRS set coming in today and I'll do a valve grind and see if we can get this thing running. I've also sourced an MQ manifold and single 2 barrel to see if it's the carbies playing up as well. But one thing at a time. Cheers for all your suggestions. Quote
luvemfast Posted April 12, 2011 Posted April 12, 2011 I've got a VRS set coming in today and I'll do a valve grind and see if we can get this thing running. I've also sourced an MQ manifold and single 2 barrel to see if it's the carbies playing up as well. I'm a tad confused If you're doing a valve grind, you're taking the head off? correct? What are you trying to achieve from a valve grind? Its not going to magically fix this problem. Have you pulled the plugs out to read them yet? Maybe its time to get a mechanic to look at it if you can't diagnose the cause? Quote
Linton Posted April 12, 2011 Posted April 12, 2011 have to agree with the last post, very easy to check with out pulling the head,, before you take off the head do a compression test if the cyl is low then squirt some oil into the cyl through the plug hole about a teaspoon and re-test if the compression comes up it needs rings if the compression stays the same then it is most likey valves Quote
zedrally Posted April 12, 2011 Posted April 12, 2011 Just a long shot, but as your still using points, it could be the condenser. The Gemini problem I've experienced first hand and it was a head scratcher, very frustrating...very much like this. Good luck.. Quote
bullzed Posted April 12, 2011 Author Posted April 12, 2011 Yeah I'm going to do the wet and dry test first. If it's valves, I'll do a valve grind and this will also allow me to see if it's also a blown head gasket between cylinder 1 and 2. If it's the rings.. the car will be off the road for a while. If it's none of these.. it'll be the carbies, which will be replaced by a single 2 barrel MQ setup until I can afford another setup. Just a long shot, but as your still using points, it could be the condenser. The Gemini problem I've experienced first hand and it was a head scratcher, very frustrating...very much like this. Good luck.. The condensor has been replaced already. All new electricals on the engine at this time. Quote
salty Posted April 12, 2011 Posted April 12, 2011 with readings that low and that different, more than 10% between the highest and lowest cylinders, I would expect some major work will need to be done :'( Quote
bullzed Posted April 12, 2011 Author Posted April 12, 2011 with readings that low and that different, more than 10% between the highest and lowest cylinders, I would expect some major work will need to be done :'( Turns out it's the rings Time to build that race motor then! Quote
datozed Posted April 12, 2011 Posted April 12, 2011 Think it may be ignition timing , take out number one plug, poke something down the hole, roll the crank backwards and forwards to locate top dead centre . When your sure it is on top dead centre check to see where the mark is on your harmonic balancer, I think it may be possible that your harmonic balancer has slipped . So if you are timing it with a light your timing will still be wrong have seen this twice before . Quote
silverz Posted April 14, 2011 Posted April 14, 2011 I take it the missfire is now cured after sorting the issue with the rear carby? If it is that low on power, have you checked the harmonic balancer. Mine started to come apart causing it too slip hence the timing marks were in the wrong spot. A rebuilt harmonic balancer made all the difference. If this is the case try timing it by ear, it will be rough but will give you some idea. Maybe a long shot but worth considering. Regards Peter Quote
bullzed Posted April 14, 2011 Author Posted April 14, 2011 The car is still misfiring badly to the point that it hardly keeps itself going. It's really hard to adjust the timing by ear as the cam makes the car sound rough all the time. I don't think it's the harmonic balancer however there were many things that we've found to be wrong with the engine yet it still ran. Fuel blockage to rear carby, no vacuum to automatic advance/retard, timing was out, bad connection to the distributor, weak coil and unbalanced carbies... it still ran with all of that wrong on it... so the problem must be something internal.. probably burnt the valves in cylinders 1, 2 and 3 from the front carby running lean... We can only try, but cheers for all your suggestions... Quote
