hi guys, i bought a zed not long ago, and start playin with it..... anyway the car since i bought runs out of tune when its hot weather and it runs beautiful when its rainy or early morning, when its hot weather is also keep fowling the sparkplugs,
i called several mates and they said its needle and seat thinngy, read forums they have different setup. instead of wasting money on parts and time myself, i decided to may be send to a mechanic that is experienced with zeds... any recomendations?
thanks guys.
i post in vic section coz i need urgent before i sold my Twin turbo wagon 4WD family car.
You could try Dazzed on this forum.
He is a mechanic with his own shop and has lots of Z experience.
Daniel @
DJM  9808 2590
It's in Burwood
Or try Zshop or Z factory maybe?
Hi Buddy,
We need to catch up next week sometime for a chat at your shop.
On the carbie side of things, you will get a reply "Isn't that right guys?" Peter, David, Dimitri, Lurch, NZ Mike ?
In the meanwhile, there are a bunch of members who have been discussing a group buy of CF intake plenums and suggested they contact you.
Look at the thread entitled "Group buy cold air box"
John
Daniel @
DJM  9808 2590
It's in Burwood
Hi Topstage,
I would recomend Daniel he has helped me out a bunch, and has done a great job on my Z.
Best of luck
Johnboy
hi i hear good things about dazzed and he is not to far away .but if he is to bizzy you can bring it down to morwell and i will sort it for you. but do give him a call first
Are you running with a heat shield between exhaust and your carbies?  You may be boiling fuel in the lines or even the bowls?
MaygZ
Edit:  Now that I have read the below post - stuck choke throttles is the more likely. :P
I'm not too far away; I can have a quick peek... Have you checked if the chokes are not stuck on? A cold engine always needs more fuel and as it warms up needs less. I can check your needles and seats for wear or one or both could be worn letting in too much fuel. Only guessing but let me know if you want me to come and do a quick check.
