Hi,
Anyone have any lash pads lying around? Just need one, I have attached a picture to show you what happened to mine. The mechanic said it was due to valve bounce. The car has a mild cam in it and i know that effects the overall thickness of the pad.
The thickness i need is 5.10mm from the bottom face to the cut away face. It might be even a stock lash pad, as I was told some people didnt bother changing the lash pads after fitting a new cam. I am in need of one urgently so if you have one please let me know.
Thanks
Sach
5487130753
http://www.flickr.com/photos/smeegama/5487714754/
http://www.flickr.com/photos/smeegama/5487130753/
Hey Sach,
Long time no see!! There is a place in dandenong that machine them to your exact specs. If you PM peter mc26 if should be able to tell you the place!!
Ben
Hey Ben,
yeah mate took abit of a break from the zed and done some traveling. Thanks for the tip, I'll try get in contact with Peter and see how we go. I want to try and make the cruise down to Marysville, hope to see you there.
Dimitri, I have no idea what the thickness of the standard one is. If you get a chance could you possibly have a look for me?
Measuring one by eye looks about 4.4mm from the distance you measured.
Just measured mine, all up is 4.3mm, but they have an indentation where it sits on the valve of approx 1.23mm. If you need 5mm, you may have to get one made.
