GongZ Posted December 28, 2016 Posted December 28, 2016 Tridon TF122 - THERMAL FLASHER - Not polarity sensitive - can be used on positive and negative ground vehicles. - Suitable for flasher & hazard light applications. - Flash rate is influenced by load variation. - Operating Voltage 11 - 15 volts D.C Load Rating 2 to 6 x 21 watt, 12v lamps (6 x 21W = 126W /12V = 10.5Amps) http://www.tridon.com.au/products/Tridon/35/478/flashers-and-relays/104172/flasher-relays-thermal/1777/TF122 Ponyo240z and gav240z 2 Quote
GongZ Posted December 28, 2016 Posted December 28, 2016 For anybody following this topic - I have edited post #48 to correct the polarity. Quote
Administrators gav240z Posted December 29, 2016 Administrators Posted December 29, 2016 Thanks mate, I fixed my post also. Although it seems to work either way? Any potential negative side effects of having them 1 way or the other? Disclaimer: I'm not an electrical engineer (far from it). Quote
GongZ Posted December 29, 2016 Posted December 29, 2016 Thanks mate, I fixed my post also. Although it seems to work either way? Any potential negative side effects of having them 1 way or the other? Disclaimer: I'm not an electrical engineer (far from it). An electrical engineer used to live in my house! Most, but not all, flasher cans are not polarity sensitive. Having said that, I just did a Google search for "Niles flasher polarity" and the top 10 results all said "Make sure that you maintain proper polarity" or words to that effect. It looks like you just got unlucky. The description of the Tridon TF122 that you have now used says that it is not polarity sensitive. The reason that I chose an electronic unit over a thermal unit is that I might change to LED bulbs in the future. One advantage of thermal units is that if a bulb blows, they tell you so because they start to flash very quickly. gav240z 1 Quote
GV260 Posted January 7, 2017 Posted January 7, 2017 Great post guys. So what's the difference between the series 1 dash hazard switch and the console hazard switch below (are they different markets) and where does the on/off dash decal go? Quote
Administrators gav240z Posted January 7, 2017 Administrators Posted January 7, 2017 The middle picture for the console is for the parker lamps, not a hazard switch. Left photo is the early hazard switch, middle photo is defogger + parker lamps (Japanese market) and the right photo is the on off switch decal that would sit next to the switch to indicate direction for on and off. RHD dashboards don't appear to have the indentation for that decal/sticker. Ponyo240z 1 Quote
Six_Shooter Posted January 23, 2017 Posted January 23, 2017 Didn't European markets get the Parker lamps as well? Quote
beeto Posted September 25, 2017 Posted September 25, 2017 Very helpful read thanks guys. I am in the same situation, i have found the loop wire, but cant find the other 2 wires. I have found 2 attached to a sounder? is this what i am after, or other wires somewhere else. Also, i dont have a switch, so was looking at these, will any of them work? https://jdm-car-parts.com/collections/electric-components-nissan-datsun-fairlady-z-240z-260z-280z-280zx/products/hazard-switch-for-1969-1971-1-2-datsun-240z https://jdm-car-parts.com/collections/electric-components-nissan-datsun-fairlady-z-240z-260z-280z-280zx/products/hazard-switch-for-1971-1-2-to-1972-datsun-240z https://jdm-car-parts.com/collections/electric-components-nissan-datsun-fairlady-z-240z-260z-280z-280zx/products/hazard-switch-nos-for-datsun-240z-series-2 Thanks all! Quote
AndBir Posted September 25, 2017 Posted September 25, 2017 Very helpful read thanks guys. I am in the same situation, i have found the loop wire, but cant find the other 2 wires. I have found 2 attached to a sounder? is this what i am after, or other wires somewhere else. I think the two wires (green-white) shown in the last photo (?going to the sounder?) are for the turn signal flasher unit. Maybe this sounder has been added to make a louder noise when the indicator(s) are going? gav240z 1 Quote
beeto Posted September 25, 2017 Posted September 25, 2017 I think the two wires (green-white) shown in the last photo (?going to the sounder?) are for the turn signal flasher unit. Maybe this sounder has been added to make a louder noise when the indicator(s) are going? Thanks for the reply. Yea, i cant find anything that shows they came with sounders stock. Quote
Administrators gav240z Posted September 25, 2017 Administrators Posted September 25, 2017 That sounder thing is not OEM, never seen it. Sounds plausible that maybe someone wanted to hear the indicators better and had that fitted? Any switch will do, the differences are dependent on year. The flash type is early (hence I prefer it) the standard looking hazard symbol was 72+ and then in 73 they got the pull out type which lights up via optical fibre cable. Quote
AndBir Posted September 26, 2017 Posted September 26, 2017 (edited) Very helpful read thanks guys. I am in the same situation, i have found the loop wire, but cant find the other 2 wires. I have found 2 attached to a sounder? is this what i am after, or other wires somewhere else. Not sure if this wiring diagram (wire colours / connector type) will help as it is for the first of the 260z models and it appears the early 240z models did not have the L shaped connector. Edited September 26, 2017 by AndBir Quote
twoforty z Posted November 4, 2017 Posted November 4, 2017 I recently did this in my 1971 240z while i had the dash out and was redoing my wiring. Bought an american flasher switch, bought a 12v flasher unit and plugged it into the green/white and blue/white spade connectors that come out of the dash harness with all the other plugs. Bingo bango bongo, hazards! Easiest mod ever, if only it was all that easy. gav240z and GongZ 2 Quote
Administrators gav240z Posted November 4, 2017 Administrators Posted November 4, 2017 It's 1 of the most satisfying modifications to do to an AU market 240z! Quote
AndBir Posted January 17, 2018 Posted January 17, 2018 NILES 12V Flasher switch supplier in NZ : http://www.nzdatsunparts.co.nz/shop/240z-260z-280z/genuine-datsun-nissan-flasher-units?gn=240Z%20260Z%20280Z&gp=21 Quote
AndBir Posted January 17, 2018 Posted January 17, 2018 I see flasher relays - not switches Yep, I misread the title - still may help someone looking for the relay :-( GongZ 1 Quote
GongZ Posted January 17, 2018 Posted January 17, 2018 Yep, I misread the title - still may help someone looking for the relay :-( Yes - still a good find - keep it up! Quote
Swirlything Posted August 5, 2021 Posted August 5, 2021 hello - just a question, those of you that bought the American hazard switch, did you get the switch rebuilt prior to installing or just bought a second hand one, removed the loop back plug from your wiring harness, crossed your fingers and plugged the hazard switch straight in and hope for the best? Quote
Administrators gav240z Posted August 5, 2021 Administrators Posted August 5, 2021 2 hours ago, Swirlything said: hello - just a question, those of you that bought the American hazard switch, did you get the switch rebuilt prior to installing or just bought a second hand one, removed the loop back plug from your wiring harness, crossed your fingers and plugged the hazard switch straight in and hope for the best? Switches are pretty robust. I've got 1 that's broken (inside plastic) which I have been meaning to 3D print forever to fix. The switch can be disassembled and cleaned if required, but so far most of mine have worked fine. It's the flasher can that usually packs it in. Quote
beeto Posted June 5, 2024 Posted June 5, 2024 @gav240z So to clarify you only used the 6 pin (5wire) connector that has the loop back, and the other 3pin one is just floating free? and the hazards worked fine? Quote
Administrators gav240z Posted June 8, 2024 Administrators Posted June 8, 2024 On 6/5/2024 at 8:21 PM, beeto said: @gav240z So to clarify you only used the 6 pin (5wire) connector that has the loop back, and the other 3pin one is just floating free? and the hazards worked fine? It's been a long time, but I believe the other plug is for the Japanese market Parker lamp switches. So yes it works fine even if that other part of the loom is left as is. Quote
