zeds4ever Posted December 18, 2010 Posted December 18, 2010 :-\ Wondering if anyone has fitted a R33 wiper motor into a 76 260Z. Regards :Alan. Quote
Moderators Zedman240® Posted December 18, 2010 Moderators Posted December 18, 2010 I fitted a wiper motor out of a Honda Civic (93?) to upgrade my one. It's a lot faster but parking the wipers is abit annoying. Quote
mossy Posted December 18, 2010 Posted December 18, 2010 The other option Dimitri is to do what I plan on doing, never drive your z in the rain Quote
Moderators Zedman240® Posted December 18, 2010 Moderators Posted December 18, 2010 Thats always the plan but as you know with Melbourne weather, you leave with the sun and come back with wall clouds and large hail in the arvo! Quote
mossy Posted December 18, 2010 Posted December 18, 2010 Very true mate. Another option Alan is the honda civic wiper motor, this writeup says its for a 240z though not sure how it would go on a 260 http://www.classiczcars.com/forums/showthread.php?t=28989&highlight=wiper+upgrade Quote
Riceburner Posted December 19, 2010 Posted December 19, 2010 Is there a faster motor that will self park? Quote
Moderators Zedman240® Posted December 19, 2010 Moderators Posted December 19, 2010 My Civic one does self park but it does it slightly on the high side. If you turn it on and off at the right point, they sit nice an low. Quote
Riceburner Posted December 19, 2010 Posted December 19, 2010 That link doesn't work for me :-\ Was it hard Dimitri? Quote
zeds4ever Posted December 19, 2010 Author Posted December 19, 2010 Thanks Dimitri for info, whats the drama's in fitting this . With the Civic unit can I use the existing actuating arms to wiper blades. Tried to get access to thread suggested but no luck. Regards :Alan. Quote
FLEXZED Posted December 19, 2010 Posted December 19, 2010 hey Alan All the info you need is here, this is from a honda accord which i think is the same as the honda civic http://atlanticz.ca/zclub/techtips/wipermotor/index.htm Loui Quote
nat0_240_chevZ Posted December 21, 2010 Posted December 21, 2010 My Civic one does self park but it does it slightly on the high side. If you turn it on and off at the right point, they sit nice an low. just park it, then re-adjust the position of the wiper ams on the spindles!!!! hopefully will alweays then park in that pos'n nat0 Quote
Moderators Zedman240® Posted December 21, 2010 Moderators Posted December 21, 2010 just park it, then re-adjust the position of the wiper ams on the spindles!!!! hopefully will alweays then park in that pos'n nat0 It's a bit hard to explain, but when they park without my help, and sit a tad high, when I go to switch them back on, they keep travelling down for a split second then start the upward stroke as normal. If I re-adjust the arms on the spindle, the wiper blades will hit and run over the windscreen seal then travel back up. It must be the timing in the wiper motor itself that needs adjusting. Not a big issue for me, as long as the wipers work well, that's all I care about. That link doesn't work for me :-\ Was it hard Dimitri? Nope, just have to re-drill 3 holes in that metal plate that holds the original wiper motor and all the original zed arms and linkages bolt up. A little wiring is needed; just make a new in-line plug in from the original loom to the new motor. I'll try and find the thread on here somewhere.. Quote
mossy Posted December 21, 2010 Posted December 21, 2010 That link doesn't work for me :-\ Sorry guys you actually have to be logged in to see it. Quote
Moderators Zedman240® Posted December 21, 2010 Moderators Posted December 21, 2010 Found my thread about it; http://www.viczcar.com/forum/index.php/topic,2993.0.html I still have the wiring loom schematic on file if anyone needs it. Quote
zeds4ever Posted December 21, 2010 Author Posted December 21, 2010 Thanks again Dimitri, got a circa 93 Civic motor in xclnt cndtn for ($30) Ebay. Checked out Atlanticz site & your thread also. Your finished job was more impressive especially the wiring concept. Can you possibly give a more detailed description of how you achieved this result. Regards :Alan. Quote
