Hi guys,
            would I be able to get away with running a mechanical fuel pump on a hot L28 with tripples or will it starve of fuel? If I have to go electric, can I install it so that no mods are required to fuel lines etc, eg I can change back to stock setup easily? Cheers.
I ran with a stock 260Z electric fuel pump with triple 40 Dellorto's without any issues. Unless you are running a blown Keith Black Hemi on alcohol, a good electric pump should be fine.
I run a pierbug electric pump from efi hardware (part no. 864-340). I have it mounted near the tank with a relay for stable voltage and get 2.9psi at the carbs, had it for 6yrs without a problem. They are good for up to 340hp  ;) I just got a spare to fit and leave in there incase the other fails for some reason.
How have you guys mounted the pump and done the wiring? Did you use a the standard 260Z electric fuel pump bracket. How do you run the wiring? Cheers.
Yeah mine is mounted where that was, also had factory wiring already there  :o used that to energise relay then ran a fused active from the battery. If you don't do this it will fluctuate from voltage drops in the loom, I didn't use a relay originally and you could hear the pump speed up/slow down when the indicator was on at traffic lights  :D They are a very quiet pump compared to some, I've tried a Carter Rotary and it was crazy loud!
By the way it's a Pierburg pump not Pierbug as I put in my previous post...
Most zeds have a large green wire that runs to the rear with the wiring for the fuel sender on the tank; Most of the time its tapped up so it cant be seen easily. It should be there.
Pauly - did the engine ever lean out or starve at higher revs?
Zedman - is one of the green wires a power because this setup would go on a car that originally had a mech fuel pump. Or do all looms include the wiring for the electric pump?
Cheers.
Dim
are you saying that you can use the green wire as a possible feed for a small pump ? does a 240's wiring have this green wire ?
Im using it now for my EFI pump and its actually quite a large diameter wire. The plug is taped to the loom up behind the heater control panel; its a white "H" shape plug with 2 large green wires. One side has power, all you need to do is wire up a relay and it's just about done.
