benny Posted October 12, 2010 Posted October 12, 2010 Hey Guys, After a thrust bearing to suit 240z Gearbox and correct clutch, anybody have one or know the part number from nissan?? Cheers, Ben Quote
Administrators gav240z Posted October 12, 2010 Administrators Posted October 12, 2010 I don't know the part number, but I remember doing this job on my 260z and I walked into East Coast Auto down in Ormond area and just asked for the part. Seems to be a pretty common part, so should be able to get it without too much drama. Don't think it makes a difference if it's genuine Nissan part of not. Hope that helps. Quote
zzzzed Posted October 12, 2010 Posted October 12, 2010 shold have posted this yesturday. i could have thrown one in the box. but you are better off getting a new one Quote
Scoota G Posted October 12, 2010 Posted October 12, 2010 I have an aftermarket part number. Clutch Kit NSK6052. Quote
benny Posted October 12, 2010 Author Posted October 12, 2010 sorry should of been more clear i will be running a 240 box with a NSK6097HD Clutch Kit, just need the thrust bearing and carrier, Quote
Zedback Posted October 12, 2010 Posted October 12, 2010 Just did a bit of research on this http://www.viczcar.com/forum/index.php/topic,7830.msg74609.html#msg74609 NSK6097 is a later style 47mm deep clutch so you will need the later model slightly longer carrier (53mm). MSA carry them (and probably most every other clutch shop). If your 240z trans has it's original carrier it will be the shorter one. Quote
benny Posted October 12, 2010 Author Posted October 12, 2010 so just ask for a 53mm bearing carrier?? Quote
benny Posted October 14, 2010 Author Posted October 14, 2010 Hey guys having some trouble here... is the correct carrier from a 280ZX? and is the 53mm including the bearing?? Quote
luvemfast Posted October 14, 2010 Posted October 14, 2010 Sorry mate, can't help. Don't actually know Quote
benny Posted October 14, 2010 Author Posted October 14, 2010 ive found this on the SAU Forum Part numbers for carriers and there lengths- 30501-A3800 12mm, 30501-N1601 14mm, 30501-U0200 16mm, 30501-S0200 18mm, 30501-B6000 20mm, 30501-S0160 22mm, 30501-K0404 24mm, 30501-K0510 26mm, 30501-N1600 28mm, 30501-N8400 30mm The new bearing ive got is 20mm tall which carrier should i go for?? Using an NSK6097-HD Clutch Kit Quote
Zedback Posted October 14, 2010 Posted October 14, 2010 Benny, haven't tried to buy one myself yet I'm just going on what I've read. Given you are after the later longer style then asking for one to suit a 280zx should do. Take a tape measure with you when you buy it and measure it. Look at what MSA describe http://www.thezstore.com/page/TZS/PROD/PCC08/21-2122 Quote
benny Posted October 14, 2010 Author Posted October 14, 2010 the 280zx carrier is supposedly this nissan part number- 30501-N1600 and is 28mm which only gives 48mm total!! Quote
