red76z Posted June 12, 2010 Posted June 12, 2010 Still looking 4 a 6 speed box to suit the ls1. But I am wondering if the original 5 speed z box will take the hp that the ls1 will put out. It seems to take the 180-200hp from the p76 but will it survive the 300-400hp from a ls1. I have looked every where and I cannot find max hp ratings 4 the 5 speed. I would appreciate any feed back. regards red76z Quote
zr240 Posted June 13, 2010 Posted June 13, 2010 no, no and no. not even a chance. Its the toque that will really kill it. But it wont handle the hp either Ash Quote
NZeder Posted June 13, 2010 Posted June 13, 2010 UPDATED: The torque will kill it. I have read on a some 240SX and other S13/14 sites that say the 71C are good for about 350HP from the SR20DET/CA18DET but they are 4 cylinders not 8 so I think it would not last that long. And that is a 71C no a 71B How big is your budget? Get a RB25DET box if you want a Nissan box or just save the $$ and get new Tremec (I think around $4000AUD new - but then you need bellhousing etc) ie a TKO 600 good for 600lb/ft and get the ratios you want too boot - but not cheap if you are only thinking $1000 for the trans + clutch. However you would want a good clutch too so that would be close to $1000 if you go twin plate 7.25 - the with a Tremec and Chev they are cheaper than getting Nissan splined Twin Plates from the likes of Tilton, PowerTrain, Quartermaster etc. Quote
pauly_adams Posted June 14, 2010 Posted June 14, 2010 get yourself a 300zx z32 gearbox doesnt matter wether its turbo or na there the same box they can handle over 500hp and 700 foot pounds of torque you will need a good clutch though. cheers pauly Quote
zed240au Posted June 14, 2010 Posted June 14, 2010 why not just use a t56 six speed thats designed to be behind a ls1 it fits in a 240z tunnel fine and works fine great box mick Quote
nat0_240_chevZ Posted June 15, 2010 Posted June 15, 2010 it will take the power no troubles, but the torque it will not. you would be better to use the 71c out of latter models but torque will still snap them in a few spirited uses / applications. would suggest a tremec t56 or getrag or supra as the g/box's main case is smaller and easier to squeeze into the tunnel, also you will need to consider what type of g/box x-member mounting you have ie ears or bolt from under, the ear types make it even toghter than the earlier bolt upward type. just some things to consider....... nat0 Quote
red76z Posted June 16, 2010 Author Posted June 16, 2010 Thanks 4 the handy info guys. I am still on the prow 4 a t56 box. Love to here from u if u know any one wanting to sell one. Quote
620Z Posted June 16, 2010 Posted June 16, 2010 I have an old Tremec 5 (TKO 3550) Speed you can have for $500.00. Gears a bit worn but worked no worries in my car before paying $4,000- for a new one. Can even have the old drive shaft to suit 2+2 cause I'm a good bloke. This will get you going for a year or two before requiring a new one or working out an alternative. No belhousing though. I used my old one. PM if interested. Cheers Quote
red76z Posted June 18, 2010 Author Posted June 18, 2010 thanks 4 the offer of the box will keep in mind I have a lead on about 4 t56 at the moment.Do it once, hopefully. cheers Quote
