Hey guys, i started to notice last time i ran my 26 that it was running rough. I used a lead checker tonight and noticed that cylinder 1 and 3 have very little spark. The others are fine, gave me a wallop when pulling the leads off.. though not 1 and 3. Does this mean distributor time? thanks.
As stated above work from your plugs back to your distributor. Swap a couple of plugs over then a couple of leads then check and clean the dizzy cap. If you're still running points then this may have an effect as well. I've seen a bad coil do a similar thing as well. Where the duty cycle on the coil was just about stuffed and created a pattern with an intemittant spark.
Steve
Check for faults and obvious stuff first before spending the coin. Have a look at the posts on the inside of your dizzy cap for corrosion and wear as well. Clean them up with some emery paper if they aren't worn too much. Otherwise you may need a new cap and rotor.
Steve
the dissy cap and posts seem to all look fine, the rotor button seems fine, i went through and cleaned it all up when i first tried kicking it all over. All the new parts and the cleaning ive done has only have a few hours running since i started the car some time ago. I think it might be the coil possibly. i might try that first.
Just click on the little man under posts and you can see where we are. Hope this helps. I am closer to him than you Loui.
fairdinkum Ive got a similar problem !!
my L24 is running rough ...one day perfect 4-5 days latter (when next started the motor) running rough down low..
Im curious whats the best way to test leads...a mate said to pull off the leads and using a multimeter set to 2M Ohms, put the prongs on each end take note of the readings...he said that a longish lead should get a reading of 14-17 and anything in the mid 20's means the lead may have a break.
problem is when set to 2M ohms im getting different readings..my lead readings are:
1.....4.37
2.....3.74
3.....3.91
4.....4.26
5......4.68
6......4.77
1 being the shortest, 6 the longest...what can I decifer from these figures ?? does this mean my lead no1 is a bit dodgy ?
by those figures.. your not even geeting 14-17 i the first place??
Ive got a lead checker.. which has a light on it.. and it flashes when it has a signal.. and how bright it is determines how strong the spark.. etc.. hmm.. try a spare coil.. thats not a bad idea..
Ohms is resistance so the low numbers are a good thing. The higher the reading the more resistance you have in your leads which means you have less spark being delivered to your plugs. ;)
Ok, I didn't buy a coil, i got a new rotor button, and points. That didn't fix the issue. So i pulled out all the plugs, and they were all black and covered in goo. So i cleaned them up and now its running on all six again. I think the carbs need a good tune.
