Does anyone have a spare 240Z "A" grind cam laying around?
Have been told that putting one of these cams in with the triple Mikuni's will be benefitial.
PM me
or
email simon.ray@optusnet.com.au
or
call 0400 395 898
If you can help.
Thanks,
        Simon
Simon, I run a 72deg cam, It seems to 'come in' at around 3000rpm. That suits me fine, good for street and means I don't have to rev its tits off on the track also. I only had su's when first fitted but seemed to make a noticeable difference. I have info on the correct lash pad thickness and where to dial the camshaft in at, if you want it just pm me.
By who?
You will get SFA difference out of a A Grind cam, Simon.
God I hate some of these myths...
Lou M
Until I do some work to the internals, an "A" grind will suffice. From what I believe, it will open up the top end slightly. Thats all I'm after at the moment.
Once a rebuild is done, a 74° cam will more than likely go in.
Simon
If you have an L28 C grind the specs are identicle to the 240 A grind  so no difference. The A/C has better duration than the F grind that was also installed in the L28e's...............check which cam you already have.
Lou's recommendation was obviously based assuming you had an F ...and on testing cams in my engine on the engine dyno......not anecdotal evidence..........the stock 240 A grind was found to be superior to the stock C and F grind. (more duration and intake lift)
The stock A grind has huge torgue below 4500 and makes peak power at only 5500 so it is ideal for road use as the power is always there ......not so great for track as it drops off quickly after 5500-5800
BTW
I got my spare A grind from Lindsay at the Z Shop.............he may be worth a try ?
I have since reground it to a 70 deg Roadster profile which I am yet to test...this should move peak power to around 6200
Alan
Thanks for the info Alan. I'll check this weekend to see which cam I have.
No offence Lurch, but sometimes sharing info is more useful than hearing ones opinion when it comes to learning.
I have an F L28 cam, a 260z cam can't remeber cast number, and a late L24 out of a skyline and an L24E cam aswell.
LOL.
However it woudl be cheper to get a new regrind cam, thay are only $160.
None taken Simon :)
It's just that for all the effort you'd go to in obtaining a A cam & then changing it, I would have thought it'd be easier & just to get one reground to a more agressive profile in the first place...
ill have a look for you if i have one i know that i have one from my 260z engine and i may have one from my L28 if my L28 has one i may be able to help you out.
also sorry to jack the thread a little but has anyone got any info on a B4 grind cam ??????
cheers pauly
None taken Simon :)
I think where Simon is going as that an A grind is the best starting point for a regrind as it has the largest base circle dia and highest lift and can be reground in stages. Rather than install a 72 deg straight up and find that you have lost all you low down mumbo and you need to rev it beyond 500 all the time to get any performance.
Simon............what are you aiming for? something that is tractable around town or a flat out race cam?
Pretty much on the head Alan.
Good base to start from.
As my car is not a race car, but used for motorsport,  I'm after an all rounder. Something that is nice to drive, but has some life and excitement in it with "spirited" driving.
Cheers  :)
