peter bird Posted November 1, 2025 Posted November 1, 2025 Weird stuff happening with indicator stalk. Left hand blinker works ok, click over to the right and blinker works for a second then stops, then it starts smoking through the stalk. I cleaned the mechanism and put light oil on moving parts, but no improvement. Next step prolly check earth. Failing that, I have no idea. Thoughts guys? Quote
C.A.R. Posted November 7, 2025 Posted November 7, 2025 Sounds like you have a dead short somewhere. Start unplugging 1 wire at a time & see what happens. peter bird 1 Quote
AndBir Posted November 8, 2025 Posted November 8, 2025 On 11/1/2025 at 9:21 PM, peter bird said: I cleaned the mechanism So you opened up the indicator mechanism that internally has a ball bearing and rocker plate? peter bird 1 Quote
peter bird Posted November 12, 2025 Author Posted November 12, 2025 (edited) Hi guys. I had a second go at it and this time pulled apart the mechanism and cleaned up the terminals /contact points. One side was in poor condition. Hit it with some super fine steel wool and put it together. Wasn't expecting much, but suddenly discovered I had a win! Blinkers work perfectly again and no smoking. Edited November 12, 2025 by peter bird AndBir and OdinZ 2 Quote
