. Posted June 18, 2009 Posted June 18, 2009 It looks like I might be buying a 280zx this weekend for parts. Just getting the word out early because I don't want to store much of the car once I pull it apart. It is already missing the diff, rear suspension carrier, bonnet and radiator. I already have a buyer for the engine. It does have a 5 speed gear box and all the other various parts. Let me know if you are after somethin specific. (eg electronic ignition, gearbox, panels etc) I'll post more detail once I have taken delivery (assuming it doesn't go pear shaped) Quote
dorifticon Posted July 3, 2009 Posted July 3, 2009 if it has a 15/16" brake master cylinder in the right configuration to bolt up to a 260z (ie the flare-nut dealies are mounted on the side) then I'd be interested. Andrew Quote
Aaron Neubauer Posted July 6, 2009 Posted July 6, 2009 What series is it? I may be interested in the rear calipers or has that already gone? Quote
kalium Posted July 15, 2009 Posted July 15, 2009 Hey Greg you don't happen to have the fuel pressure regulator do you? Ray Quote
luvemfast Posted July 15, 2009 Posted July 15, 2009 Are the front indicator/parkers any good? Mine are cracked and could use replacing. How much do you want for them? Ta, Simon Quote
luvemfast Posted July 16, 2009 Posted July 16, 2009 I will check them and get back to you. Can you confirm that you are after the blinkers from the front bumper off a series 1 280zx Yeah, sorry. Its a series one, the chrome and black plastic bumper. Cheers, Simon Quote
kalium Posted July 17, 2009 Posted July 17, 2009 I would. Mate you can have it for free. Just pay for postage. Let me know your address if you want to proceed. Thanks Greg That would be awesome mate. I'll do a few other tests first to make sure that it is the pressure regulator that has indeed gone bust. I'll let ya know. Quote
chris240 Posted July 17, 2009 Posted July 17, 2009 Greg do you still have the ignition coil ? chris Quote
OZ001 Posted July 17, 2009 Posted July 17, 2009 Yup, You can get the bumper. How does $20 plus postage sound? I would give it to you for free but I will need to spend some time packing it up. sounds good to me PM your details please Quote
xa1973 Posted July 17, 2009 Posted July 17, 2009 Are the front indicator/parkers any good? Mine are cracked and could use replacing. How much do you want for them? Ta, Simon Hella make an almost identical front blinker assembly which I used on my ZX...let me know if you want the part number........... Quote
pklord Posted December 9, 2009 Posted December 9, 2009 Hey how's it going. I have an 1981 280 ZX and am looking for a new front bumper. I don't really mind if it's a bit of a mess and needs paint ect. just as long as it is straight. Also I'm looking for the fan control module that has a heat sink attached and is screwed underneath the dash under the fan and monitors the temp as the air flows past the heat sink that sits inside the air con. duct. Looks like I need a new compressor for the air con. So if you have any ideas where I can get a compressor I would appreciate it. Thanks, Phil. Mob. 04 1237 5484 P.S. are you anywhere near the Sunshine Coast, Qld? Quote
peter t Posted December 11, 2009 Posted December 11, 2009 Hi, is the box still available and how many dollars? Quote
peter t Posted December 11, 2009 Posted December 11, 2009 What a shame. Already have one but I got burnt as it is not in very good condition. I guess that is the risk you take. No blame to the guy I got it from as he would not have known. Quote
280ztrackcar Posted July 28, 2011 Posted July 28, 2011 hi was wondering if you have the drivers and passenger side door windows and tracks as well as the regulators for the doors etc have a track car and all has been striped out trying to rebuild it so ant bits would be great Quote
