sull Posted May 19, 2009 Posted May 19, 2009 I have a 260z 2 seater project, which is getting cut up and parted out. I will take offers for whole car/parts but it has been tubbed and set up as a drag car parts- Hard to find roof panel in excellent condition, no rust, suit anyone wanting to get rid of a sunroof in their 240z or 260z 2 seater $450 rare 260z 2 seater tail lights and surrounds $250 front apron/ lower valance, complete with indicators all in good condition $140 Plastic interior tail light panel, good condition $45 260z dash, needs recover, but comes with all gauges, steering column switches and wiring loom which are all in good condition $80 cowl panel in good condition $40 inspection panels $30 for the pair 260z 2+2 seats, need recovering, $40 the pair plastic engine bay air ducts $10 for the pair 260z front suspension and steering components; including struts, steering column,sway bar, lower control arms, cross member, etc. $ offers 260z chassis rails and inner guards $ offers 240k single piston callipers, brake booster, master cylinder $ offers All parts are located in the Adelaide hills. I'm not on the net that often, so if your interested its best to call or text Adam on 0422 209 234 Quote
stevo_gj Posted May 19, 2009 Posted May 19, 2009 rare 260z 2 seater tail lights and surrounds $250 Aren't these the same as for 2+2s? Quote
C.A.R. Posted May 19, 2009 Posted May 19, 2009 Sull, why are you cutting the shell up? Surely someone would wat it for a few hundred $$$ Better than looseing another 2-seater Zed to the scrapper Quote
chartoo Posted May 19, 2009 Posted May 19, 2009 hmm my 2+2 tailights didnt fit on my 2 seater and vice virsa..... Quote
Administrators gav240z Posted May 19, 2009 Administrators Posted May 19, 2009 hmm my 2+2 tailights didnt fit on my 2 seater and vice virsa..... Tail lights are the same, rear garnish is different for the 2 seater. 2+2 is slightly wider in the buttocks area. Quote
Moderators Zedman240® Posted May 19, 2009 Moderators Posted May 19, 2009 Easiest way to tell is the 2+2's have these two vertical little raised "bars" between the reverse lights and number plate whereas the 2 seaters have none. Quote
sull Posted May 20, 2009 Author Posted May 20, 2009 gav240z is right, the lights are the same but the garnish is different. lurch, I would prefer to see it kept whole, but someone has already cut out the rear suspension, so that limits what you could do with it (was on here as potential auszcar drag project in a few threads). Adam Quote
warrenz Posted May 20, 2009 Posted May 20, 2009 Plastic interior tail light panel, good condition $45 Anyone know if this is the same as the 240 panel? Adam, is it black, does it have speaker holes cut in it or it is still standard with the removable panels? Any chance of a photo it is meets above criteria? You can email to kwarrenh@bigpond.net.au Where a bouts in the Adelaide Hills are you? Warren Quote
