http://www.viczcar.com/forum/index.php/topic,3142.0.html
As you may already have seen on the above post, I have Rota RB wheels to suit Zeds in stock.
In fact I have a few too many of them in stock right now, so I'm offering a special deal for forum members. If you PM me through the forum to order, I will give you free freight (within Australia) and the following discounted prices:
15x7 +4 $175ea
15x8 +4 $195ea
16x7 +4 $220ea sold out
16x8 +4 $245ea
17x8.5 +4 $280ea
17x9.0 -13 $300ea
17x9.5 -19 $310ea
These prices are only available while current stock lasts.
if one of my clients decides to pay an invoice sometime in the next millennium, I am there with knobs on.  :D
15x7 fronts and 15x8  rear.
I seem to remember that you could get someone to anodise/powder coat the centers? Is this still true or am I dreaming of red rimmed time attack volks ?
Mike.
Mike.
No, your dreaming you had taste...
Mike.
$60 each in a single colour, don't know about the red rim bit
Since I just sold three sets of 17x8.5 I have only one set of these left, but everything else there is plenty of stock.
Just tried a variety of wheels on my car. 15x7 front and 15x8 rear fits well. 16x7 front and 16x8 rear (pictured) fits very well and looks good too. the 16x8 needs a 4mm spacer to clear the hub at the front but the centre cap still won't fit on.
17x8.5 will bolt on at the front without a spacer, but you would need very stretched tyres to clear the spring (or coilovers) so again a 4mm spacer makes things easy and the center cap will fit.
Rota Grid 16x8 +10 wheels will bolt straight on at the front but again the wheel is very close to the spring so a spacer will allow you to fit a decent tyre size (or you could change to coilovers).
Here's 15x7 front and 15x8 rear.
The tyres are too small (195/60 front and rear) but that's all I had lying around.
I would suggest 205/60 front and 225/55 rear if you can get them.
Thanks for the shot of the 15's RBs . That has made my mind up over the 16's.
You are right however the 225/50/15 options in tyres are a little hard to find.
I will jump on these when I got some spare coin.
I know this is probably a silly question, but is there any possibility there would be a configuration of the offset on the 17" ones on the 16" ones?
I just think that 17" is too big but it has the perfect offset, and i would definatly go for the 16" ones if they had that offset. (-13, -19)
Yes that would be nice, like having RS Watanabes but a lower price per rim :) I would be keen on that would be nice to have 2 sets of rims but my one set of RS Watanabes in 16x8.5 and 16x9.5 killed the rim budget a long time ago.
This does of cause rely on tyre manufactures still marketing/making the 245/45/16 which I hope the do given they were standard fitments on some cars
Exactly! hahaha.
I will prob just have to use hubcentric spacers to fill my flares, not paying for watanabes. :P
It is possible, but I would have to pay the factory US$10k for each new mould, so I would need to be very sure of selling them  ;)
That is a big investment with the $$ the way it is currently (well the NZ Passo that is, we are under $.50 to the USD :( ) I think if that was to happen I would be happy with just 1 size not a staggered sizing. So with that in mind if this was to happen I vote for the following
16 x 9 -15 in the RB-R style
I know RS Watanabes are -13 but the -15 will give a little more lip and for those with stock spring perches a bit more room too and move the lip more to the outside of a ZG Flare.
This will allow for the fitment of 245/45/16 on all 4 corners ;) or if you want the stretched look 225/45 or 225/50 as I know a 225/45 will fit on a 9" rim as this is what I had on my 240z when I had the 16x9 arrow rims on it.
That would be perfect hahaha
Thanks to everyone who took me up on this special offer. I'm out of 16x7 and low on 17x8.5, but lots of the others in stock.
  • 1 month later...
Yes, have them in stock, will clear just about any brakes and fit without spacers.
Call 02 8798 1469 to order.
Hi,
sent you a post earlier but perhaps it was lost.
I would like to buy 2 x 15x7 & 2x 15x8 for my 240Z. Am putting the Hilux 4 pot calipers on the front.Will the 15x7 take the bigger caliper o.k?
Can you let me know if you still have these in stock.
Cheers Carl
