Recently I replaced my old Gibson group A turbos with a pair Garrett ball bearing -7
turbos.
In the process I updated my intake plumbing and fitted a new 3.5in mandrel bent exhaust with a 3in straight through Magnaflow muffler.
The exhaust was made at Mufflers and More on High St. Ashburton (conveniently just at the end of my street).
I was very happy with the work of Glen (a Zed owner and enthusiast).
Had the car dynoed on Tuesday and am very happy with the result, 320.5kW ATW.
The car made more power at a lower boost and on 98 octane fuel not the 100 octane Shell VPower Racing which was a very good fuel but no longer available.
Previously the engine made 307kW ATW on same dyno.(Racepace in Bayswater).
What a tight fit of the muffler! Its a miracle they got it to fit... well done on the results; next time we have some blackouts again, your zed can supply some Kw's!
No problem Sinisha, are you running at Calder this weekend? I could bring all the equipment down and install it. Takes about 10 minutes.
Zedevan, the tank has a small surge bowl which feeds into a filter then a Carter lift pump,
this feeds a 2 litre surge tank that goes in to a Bosch 600HP pump.
The last time I ran down the 1/4 mile I had about 220 RWkW and did a 11.76@120MPH.
Dimitri, thanks for the offer but I can't make it to Calder, maybe next Sandown.
Stevo_gj, I have had the car for about 18 years, the RB26 was installed 10 years ago.
Here are a couple of pics.
Thanks Scando, very happy with the response of the new turbos.
A flat torque curve like that makes for a very drivable track car.
pic of car on dyno with the legendary Ben from Racepace twiddling the knobs.
