specialp3 Posted February 16, 2021 Posted February 16, 2021 Recently replaced my battery after 10 years and could not find any white body / black top batteries still available. The battery I have been using is a 90D26L as this fits the tray and bracket perfectly without any modifications. I ended installing a Yuasa NS70LX MF that is the same size as 90D26L but all black, had my designer mock up the original N50Z artwork and printed the decals. Looks OK, images attached. I have a couple of overs if anyone wants them, not sure what side the positive terminal should be as I have mine on the right so I can easily disconnect the negative when not using the car. Cover the postage and I shall send a set until I have no more. Cheers. gav240z, HS30-H, Ponyo240z and 1 other 4 Quote
Administrators gav240z Posted February 16, 2021 Administrators Posted February 16, 2021 Beautiful, I've always wanted to do this! I too get frustrated with lack of batteries that fit without modifying the brackets. Quote
Administrators gav240z Posted February 16, 2021 Administrators Posted February 16, 2021 I should mention I would be interested in a couple. Quote
specialp3 Posted February 16, 2021 Author Posted February 16, 2021 11 hours ago, gav240z said: I should mention I would be interested in a couple. Gav, check your messages. I think the address I have is incorrect. Cheers. gav240z 1 Quote
rajon1972 Posted February 16, 2021 Posted February 16, 2021 If there were any others I would be interested thanks. Quote
specialp3 Posted February 17, 2021 Author Posted February 17, 2021 23 hours ago, rajon1972 said: If there were any others I would be interested thanks. Hi, One more set left, send me a message with your details. Cheers. Quote
