Simonlow Posted February 11, 2021 Posted February 11, 2021 Hi all, I'm after a clutch pedal for a 280z, i believe a 260z will fit though. Quote
Administrators gav240z Posted February 11, 2021 Administrators Posted February 11, 2021 I'm not 100% sure, but I think a brake pedal can be used as a clutch pedal also. Nothing on Trademe.co.nz bru? Quote
gilltech Posted February 11, 2021 Posted February 11, 2021 (edited) Hang on. Q. By 280Z are you meaning the S30 series 280Z as sold in the USA ie. the continuation of the 240Z / 260Zs, ie. your car is LHD; or, the 280ZX (S130 series) LOTS of which came into NZ as used car Jap imports in the '80s/'90s and many for some reason (JDM?) had '280Z' rather than '280ZX' badges on them. Caused lots of confusion back then and probably still does. 260Z clutch and brake pedal shafts are different shapes Gav, the clutch pedal is straighter, so I don't know that using 2 brake pedals would work, maybe, but they would be closer together. Could always try, or modify as required. Edited February 11, 2021 by gilltech Quote
Simonlow Posted February 11, 2021 Author Posted February 11, 2021 (edited) Nothing on trademe. Yes 280z (S30) LHD. A 260z clutch pedal will fit but not 240z. Edited February 11, 2021 by Simonlow Quote
C.A.R. Posted February 11, 2021 Posted February 11, 2021 1 hour ago, Simonlow said: Nothing on trademe. Yes 280z (S30) LHD. A 260z clutch pedal will fit but not 240z. Pedals are all the same. The pedal box is different. Quote
