Zedhead Posted July 31, 2018 Posted July 31, 2018 Hi Guys, I want to convert a 240z Auto to a 5 speed and need everything required to do so. If anyone has a clutch and brake pedal assembly and or a 5 speed box (preferably a 71A 280zx box I think) that is willing to part with them, please let me know. Thanks Jeff Quote
C.A.R. Posted July 31, 2018 Posted July 31, 2018 7 hours ago, Zedhead said: (preferably a 71A 280zx box I think) Zedhead, gav240z and PB260Z 3 Quote
C.A.R. Posted July 31, 2018 Posted July 31, 2018 Do a search on this forum - what you need for the conversion has been covered before. You need a 260Z 71B gearbox, but a 280ZX will also work. You may find the diff ratio will need changing too. You might be able to collect the bits required from various sources, but if you want a 'one stop shop' for the complete conversion kit, perhaps get in touch with Les Collins: http://lescollinsracing.com/contact Zedhead 1 Quote
Zedhead Posted August 1, 2018 Author Posted August 1, 2018 16 hours ago, Lurch said: Do a search on this forum - what you need for the conversion has been covered before. You need a 260Z 71B gearbox, but a 280ZX will also work. You may find the diff ratio will need changing too. You might be able to collect the bits required from various sources, but if you want a 'one stop shop' for the complete conversion kit, perhaps get in touch with Les Collins: http://lescollinsracing.com/contact Thanks for the advice Lurch. The only reason I asked about a 280zx box was because I was told the gearing would suit the auto diff. As for the one stop shop, I think contacting Les might be the best solution. Cheers! OdinZ 1 Quote
Zedhead Posted August 2, 2018 Author Posted August 2, 2018 On 8/1/2018 at 7:35 AM, Lurch said: Do a search on this forum - what you need for the conversion has been covered before. You need a 260Z 71B gearbox, but a 280ZX will also work. You may find the diff ratio will need changing too. You might be able to collect the bits required from various sources, but if you want a 'one stop shop' for the complete conversion kit, perhaps get in touch with Les Collins: http://lescollinsracing.com/contact Hey Lurch, is this what you were looking for. https://www.ebay.com/itm/Datsun-240z-Windshield-Washer-Nozzles-Pair-Left-Right-260z-280z-240-260-280-z/292661294788?hash=item4423f8f6c4:g:GjwAAOSwMtZbU1kj&vxp=mtr Quote
