arbs Posted July 17, 2018 Posted July 17, 2018 Hi mate Im after the Drivers side rear qtr from the tail light through to wheel arch qtr window and drivers door frame. Quote
kamarchi Posted July 17, 2018 Posted July 17, 2018 Anyone know if the inner guard surrounding the battery tray is the same as a 240z? Quote
arbs Posted July 18, 2018 Posted July 18, 2018 19 hours ago, arbs said: Hi mate Im after the Drivers side rear qtr from the tail light through to wheel arch qtr window and drivers door frame. is this still available? Quote
manyu Posted July 18, 2018 Author Posted July 18, 2018 Sorry guys, shell is gone. Most of it's been cut up and are now helping put other buses on the road. Quote
TomC18 Posted July 18, 2018 Posted July 18, 2018 I know where there is another one - pretty rusty, being pulled apart currently and will be parted out after - i think the drivers side rear was rusty under the window, but the filler area appeared good Quote
kamarchi Posted July 18, 2018 Posted July 18, 2018 10 minutes ago, TomC18 said: I know where there is another one - pretty rusty, being pulled apart currently and will be parted out after - i think the drivers side rear was rusty under the window, but the filler area appeared good Where? Quote
kamarchi Posted July 19, 2018 Posted July 19, 2018 New best friend :-) seriously, would any of the following be available? 1. Battery Tray and Inner Guard (only need the section between the firewall and shock tower) 2. Left and Right Windscreen A-Pillars 3. Any section of an Inner Sill (rust repair) 4. Windscreen section between A-Pillars 5 Couple of cuts from boot floor Thanks Tom Quote
