Gtv240z Posted April 3, 2018 Share Posted April 3, 2018 (edited) Sick of your useless Zed wiper motor?! Here is a pretty serious upgrade from a Honda Civic! If you are reading this you are likely well aware of swapping the original Zed wiper motor for a 1990s era Honda Civic wiper motor . If not check this link out for the details: http://www.viczcar.c...or-replacement/ The wiper motor needs 3 new holes drilled , your bracket notched out slightly and a changeover relay wired in to ensure the wipers return to there home position. The spline on the honda motor is exactly the same as the zed one I disassemble, clean , check brushes and armature etc , reassemble and test before sending to the buyer. The wiper motor also comes with the factory socket fitted and the wiring harness that plugs in to it . I have also included the needed changeover relay, a new 6 pins plug to attached to the Honda harness and socket to replace the worn brittle one under the bonnet. you will however have to complete the wiring modifications yourself with the instructions found online. Any questions let me know, $85 Free postage Australia wide. Edited April 4, 2018 by CraigZ andyk_79 1 Quote Link to comment Share on other sites More sharing options...
Ramjetzed Posted October 17, 2018 Share Posted October 17, 2018 I would like too buy one of these please. If one is available please let me know the payment details, thanks. Quote Link to comment Share on other sites More sharing options...
Clyde60 Posted September 6, 2020 Share Posted September 6, 2020 Are these still available? Quote Link to comment Share on other sites More sharing options...
Gtv240z Posted September 7, 2020 Author Share Posted September 7, 2020 12 hours ago, Clyde60 said: Are these still available? Sorry I dont have any currently, they come from EG civic if that helps you Quote Link to comment Share on other sites More sharing options...
Clyde60 Posted September 7, 2020 Share Posted September 7, 2020 8 hours ago, Gtv240z said: Sorry I dont have any currently, they come from EG civic if that helps you Thanks for the info. Quote Link to comment Share on other sites More sharing options...
peter t Posted October 9, 2020 Share Posted October 9, 2020 If you have a sixpin conector already in your Z direct wiring as per diagram will get you going also. this is for 260. Quote Link to comment Share on other sites More sharing options...
hmd Posted February 11 Share Posted February 11 There are 2 type of relay make sure you get the changeover relay, not the normally open relay. Quote Link to comment Share on other sites More sharing options...
