Hello All,
I am after a pair of good condition 260z front hubs. Please let me know a price if you can spare a couple.
Thanks in advance,
Billy.
Have a pr of 240K units which will fit same, in good cndtn . $50.00 plus pstge .
                                       Regards : Alan .
                                       Regards : Alan .
Hi Alan,
Thank you for the offer. Can you confirm the 240k hub has the wheel mating face in the same position as the 240/260Z hub? I do not want to change the track width. And is the disk mating surface in the same position as a 260Z hub, so a 260Z disk can be used? I have read somewhere that some 240k hubs create a wider track.
Billy.
K and Z use different height disc rotors
K sedans used 253 mm diam rotors, and K coupes used 280mm diam rotors, K struts will not fit on a Z
The brake calioers all interchange, minor difference in brake line entry positions.
PM me, I have a pair of 260Z hubs. These are different to 240Z hubs, if you use a 240Z hub with a 260Z rotor the calliper wont line up.
