Hilux Brake Conversion Hub Centric Spacer
240z and 260z front hubs differ by 8-9mm in thickness. You'll need 260z hubs to get the correct offset for the calipers and rotors to mate up.
I have a 75mdl 260z 2-seater, so hopefully 8mm spacer should be ok :)
Do you have the hilux calipers?
Try bolting them on,
Before you start thinking about spacers thart you wont need.
If you havent got a set of calioers, I have a spare set, can pack n post.
I used either a 0.8mm copper washer or a 1.5mm washer (I can't remember) for my S12-8 Hilux calipers to center them over the rotor... about 3 years after I put the calipers on. It really hasn't made any significant difference to pad wear at all.
