600Z Posted December 16, 2017 Share Posted December 16, 2017 Hi Guys, Just wondering if anyone has fitted falcon xf rear discs on a zed? I see skipets here and there about them being fitted to them but I can’t find any details. Cheers, Justin Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted December 16, 2017 Share Posted December 16, 2017 I seen a 240Z with the conversion, but I didn't look at it intently enough to see 'how' it's done.IIRC they are disc over drum? Quote Link to comment Share on other sites More sharing options...
600Z Posted December 16, 2017 Author Share Posted December 16, 2017 From what I have seen unless there are a couple of different types there similar to the R31 etc with the park brake setup in the calipers as well Quote Link to comment Share on other sites More sharing options...
600Z Posted December 16, 2017 Author Share Posted December 16, 2017 (edited) I’m after a decent setup for my wife’s 2+2 as the slivermine stage 4 kit I have for it won’t fit under the Simmons. I’m looking at the Commodore conversion for the front of it as I’m thinking they will clear. Edited December 16, 2017 by 600Z Quote Link to comment Share on other sites More sharing options...
260DET Posted December 17, 2017 Share Posted December 17, 2017 Looked at early Falcon rear brakes back in my S30 days, from what I recall there were two models with handbrake calipers, one had a pretty decent rotor bigger than the alternatives. Quote Link to comment Share on other sites More sharing options...
600Z Posted December 17, 2017 Author Share Posted December 17, 2017 Yes the XF ones I’m looking at are ventilated 24mm thick 287mm diameter so combined with the commodore front it should be a pretty good setup I’d think. Quote Link to comment Share on other sites More sharing options...
HKSZ Posted December 19, 2017 Share Posted December 19, 2017 I got half way through the conversion, use the XF alloy mounts redrilled, probably start with reco calipers as the brake pins are a bastard to take on and off 600Z 1 Quote Link to comment Share on other sites More sharing options...
600Z Posted December 19, 2017 Author Share Posted December 19, 2017 Thanks HKSZ, can I ask why only halfway through and didn’t finish the conversion? Justin Quote Link to comment Share on other sites More sharing options...
HKSZ Posted December 19, 2017 Share Posted December 19, 2017 had the alloy mounts redrilled and maybe hole opened up? a rx7 rear brake setup came up for sale so bought and fitted it. Rally guys used these apparently good on Hybrid z Tonycharger72 detailed his setup Quote Link to comment Share on other sites More sharing options...
Cozza Posted December 19, 2017 Share Posted December 19, 2017 I’d be interested to know more about your rx7 brake setup, did you use rx7 front and rear? if you could post a link to the hybridz thread would be great too. Thanks Mick Quote Link to comment Share on other sites More sharing options...
HKSZ Posted December 20, 2017 Share Posted December 20, 2017 I didn't build them, used a modified r31 bracket and vented cressida rear disc Quote Link to comment Share on other sites More sharing options...
