Grille - 3Mm Rod For Through Bolts. Where To Source?
Hi,
I've bought myself a grille. It needed a strip down to straighten.Unfortunately all the through bolts broke pulling it apart.
So I will have to make some new bolts. They are 3mm OD. I was thinking of getting some 3mm rod and threading each end for the nuts.I have a die to do this.
Has anyone got any suggestions on an easy source of 3mm steel rod? I need four bits about 200mm long.
Thanks,
Greg
I always check Bunnings on line for these sorts of things, a very quick look shows 3/16" threaded rod there, there may be others as well, use 'rod' to search.
Thanks for the ideas. I haven't see threaded rod quite so small.
Peter the Hobby shop is a possibility.They might have some thin rod I could thread.
Motor bike spokes. That could work but might be a bit hard to find and I would feel bad ripping the spokes out of a classic bike wheel.
I might cruise the Bunnings isles like I often do looking for things to chop up for a project and if that isn't successful then it'll be off to my other favourite shop for building materials............... the local tip shop.
