  • grill assembled and mounted
seatbelts in ( thanks luke240 for the HEMCO tip on the belts)
just waiting for carpets from rob at z factory and have been for 3 months., keeps on saying any day now
electrics finished, had to disassemble and clean up the light switch, but the relays are now all good. now i know that the 2x relays on the sides are - they are for the high beam flasher at the end of the stalk.
just waiting on a door dovetail from warren z to line up the drivers door
got the dovertail, but when assembling the lock realised that my homemade "from bunnings" spring was too weak to hold the door button rod
so i had to make up a couple of nifty coil springs. i'll put up a quick tutorial in the interior section
when i went for a quick spin around the block, the gearbox diagnosis was confirmed - it grumbles and whines throughout all the gear, so the current suspect is the main input bearing.
waiting on prices from warren potter for a bearing set and looks like this sunday will be spend pulling out the box
bummer since i had everything out, but on the other had, could not have known that the box was bad prior since you could only diagnose this one the car is mobile
