Hi. Looking for coil overs with or without inserts. Prefer branded springs, but will entertain anything out there new or old. Just don't want to chop my own. Please PM me with offers. Cheers.
Guys..SW Motorsport busy till mid May (no staff and too much on)...Anyone could suggest experienced Z mechanic to do my coilovers?
Mca have done 2 of the garage Sanmaru cars now and are about to receive myn as soon as I remove the suspension This weekend.
You want to call josh.
Cheers Doug.
Thanks, called Oto, but couldn't say much, wasn't sure about spring rates, etc. Seems was busy. I bough carbon flares off them though. I dont want just the spring/sleeve kit. Don't want to chop my own original parts.
you have to chop your own original parts to weld the sleeves or the ready assembled BC coils.
or you can buy a completed set up from TTT for about USD $2000
Thanks..MCA?..Any links?  I looked at TTT, but this was a comment from one fitment place, which I had no time to go through..What do you think?
"....., the Techno Toy trailing arms look great, but they use a 5/8 bolt at the outer through the 16mm hole in the bottom of the strut which is a sloppy fit, if that’s an example of their other products then I am not impressed."
http://mcasuspension.com
You want to talk to Josh, Murry's son.
Josh has done a couple of of Zeds now and I have driven deusex,s 240 with them onand there a nice thing.
He will let you pick what ever spring rate you want.
redblue@mcasuspension.com
Is Josh's email, just tell him Doug mentioned him to you and he will know what your after.
Cheers Doug
And for rear control arms contact zcar63 he makes them and are fantastic quality.
Deusex has the TTT rear arms and the quality is fine.
I only went with zcar63's for the design of a true A arm over a H arm design.
Cheers Doug.
