WTB: 260Z (2+2) Front Shock absorbers
I am after front shockies for my 76 260z (2+2)
Or if someone can point me in the right direction of what brand/type to go for, that would help.
Thanks
And if the original wet legs are still fitted then I'd replace the oil first, only cost you $20 worth a try.
Thank you,
Is that relatively easy to do? does it require any special tools?
No - just a BIG shifter to undo the gland nut.
If you don't have a big shifter, a pipe wrench will also work. Well that is what I use.
