I am trying to nut out the wiring for the fuel pump. So far I have the whole I tire loom from the r33 from front to back. Once I get it running then I will chop out what I don't need.
The final pice to my puzzle is the fuel pump circuit.
I know on the ecu the fuel pump rely wire is #18 (black/pink)
And the fuel pump module is #104. (Orange)
Problem is the moduel it's self is missing. Will this stop the fuel pump relay working?
Can I bypass it and if so, do I use the black/pink wire or the orange wire to trigger the relay?
Can you use the ECU relay output wired directly to an aftermarket standard relay? (number 85 then 86 to ground. Pin 30 to 12V in and 87 to fuel pump itself.)
  • 1 month later...
I'm sure you've already figured this out by now, but the ECU grounds pin 18 to switch on the pump.  The other side of the relay coil needs to be connected to 12V.
